8.03 install question - "Print Folder"
You can use the same one as a user is typically printing one report
in only one database.
But it's amusing to watch onsite training by Epicor when they insist
on multiple training databases where everyone uses manager/manager.
Then when people print, they get someone else's report from a
different database!!
--- In vantage@yahoogroups.com, "Michael McWilliams"
<mmcwilliams22@...> wrote:
> I used the same folder that I use for 8.00 and don't see any
> problems . I think it defaults to put into
Drive:\Epicor\MfgsysData
> anyways. If you had Epicor do your install it is probably just
> Drive:\mfgsysdata That is where the XML files are stored for the
> reports you print. If you do make a new folder make sure it is
> shared with proper permissions.
> --- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@> wrote:
> > Hello,
> > I am installing 8.03 on my server that is currently running 8.00.
> > During installation, you are prompted to select a "print folder".
> > The installation directions suggest using the same location as
8.00.
> > I was wonder if people who installed 8.03 used this location or
did
> they
> > create a new location like mfgsysdata803?
> > Does it even matter?
> > Thanks,
> > Joe Rojas
> > IT Manager
> > TNCO, Inc.
> > 781-447-6661 x7506
> > jrojas@
Hello,
The installation directions suggest using the same location as 8.00.
I was wonder if people who installed 8.03 used this location or did they
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
problems . I think it defaults to put into Drive:\Epicor\MfgsysData
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hello,
they
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
