8.03 Product Configurator - Options&Comments
I usually put something like that on the next-to-last screen, last screen has an 'editor' control that displays my 'paragraph', then I use a 'set field' rule to 'push' the paragraph into the .Comment field. I'm on ver 6.10 but I think the same applies here.
rapat_mark <mtellefson@...> wrote: I am new to the configurator and I am trying to build something very
similar to John's description below. Based on the inputs we build a
description paragraph that will be displayed in both the quote and
job comments.
Do I put the code in an "On Leave" for the last field on the page,
associate it with a checkbox they click when finished working with
the options or is there a better place for this code?
I basically have it working but figure there must be a better way.
Thanks.
Mark Tellefson
Rapat Corporation
--- In vantage@yahoogroups.com, "john_f_01" <john.froehlich@...>
wrote:
> --- In vantage@yahoogroups.com, "Norman Hutchins" <nhutchins@>
> wrote:
> > Setting up a Product Configurator and I have a few check boxes
> > and a few decimal boxes that I need to be able to transfer to the
> > Order and job comments. Does anyone know how to do this? I've
> > used the Smart Description but I need to do that as well as pass
> > with things to the comments.
> > Norman Hutchins Jr.
> > Network Administrator
> > Howell Laboratories, Inc.
> Norman,
> We do this as what we call a "summary statement". We have every
> option that is chosen in the configurator pushed to the job line
and
> quote line header. Here is some example text.
> run PopulateEditor.
> Procedure PopulateEditor:
> edt95_optcom = "".
> edt95_optcom = edt95_optcom + '~n'.
> edt95_optcom = edt95_optcom + "Configuration Summary" + '~n'.
> if not chk15_quoteapproval then edt95_optcom = edt95_optcom + "DUE
TO
> NON-STANDARD OPTIONS SELECTED, PRICING INVALID UNTIL APPROVED BY
> KATOLIGHT ACCOUNT MANAGEMENT DEPARTMENT" + '~n'. Else edt95_optcom.
> edt95_optcom = edt95_optcom + "BASE OPTIONS" + '~n'.
> if chr05_model <> "" then edt95_optcom = edt95_optcom + "Model: " +
> chr05_model + " Base, $" + string(dec05_modelbaseprice) + '~n'.
Else
> edt95_optcom.
> if cmb05_eng <> "" then edt95_optcom = edt95_optcom + "Engine
> Model: " + cmb05_eng + "," + '~n'. Else edt95_optcom.
> if chr05_gendesc <> "" then edt95_optcom = edt95_optcom
+ "Generator
> Description: " + chr05_gendesc + ", " + '~n'. Else edt95_optcom.
> if chr05_genpn <> "" then edt95_optcom = edt95_optcom + "Generator
> Part Number: " + chr05_genpn + ", " + '~n'. Else edt95_optcom.
> if cmb05_voltage <> "" then edt95_optcom = edt95_optcom
+ "Voltage: "
> + cmb05_voltage + ", " + '~n'. Else edt95_optcom.
> if cmb05_temprise <> "" then edt95_optcom = edt95_optcom
> + "Temperature Rise: " + cmb05_temprise + ", " + '~n'. Else
> edt95_optcom.
> if cmb05_coolsys <> "" then edt95_optcom = edt95_optcom + "Cooling
> System: " + cmb05_coolsys + ", " + '~n'. Else edt95_optcom.
> edt95_optcom = edt95_optcom + "RATINGS" + '~n'.
> if string(dec05_kw) <> ""
> then edt95_optcom = edt95_optcom + "KW: " + string(dec05_kw)
> + '~n'.
> Else
> edt95_optcom.
> if string(dec05_kva) <> ""
> then edt95_optcom = edt95_optcom + "KVA: " + string(dec05_kva)
> + "," + '~n'.
> Else
> edt95_optcom.
> if string(dec05_powerfactor) <> ""
> then edt95_optcom = edt95_optcom + "P.F.: " + string
> (dec05_powerfactor) + "," + '~n'.
> Else
> edt95_optcom.
> edt95_optcom = edt95_optcom + "ELECTRICAL DRAWINGS" + '~n'.
> if chr65_acdwg <> ""
> then edt95_optcom = edt95_optcom + "AC Drawing: " + chr65_acdwg
> + "," + '~n'.
> Else
> edt95_optcom.
> if chr65_dcdwg <> ""
> then edt95_optcom = edt95_optcom + "DC Drawing: " + chr65_dcdwg
> + "," + '~n'.
> Else
> edt95_optcom.
> if string(dec05_modelbaseprice) <> "" then edt95_optcom =
> edt95_optcom + "Total Price:" + ' $' + string(dec05_totalprice)
> end
> This needs to be the last page.
> Hope this helps.
> John
Park yourself in front of a world of choices in alternative vehicles.
Visit the Yahoo! Auto Green Center.
Norman Hutchins Jr.
In your Rules tab, click on the top "leaf" and then add a SET FIELD rule for
your job head and quote head tables. You'll see the JobComments for each
table.
Mark W.
--- In vantage@yahoogroups.com, "Norman Hutchins" <nhutchins@...>
> Norman Hutchins Jr.
Norman,
option that is chosen in the configurator pushed to the job line and
run PopulateEditor.
edt95_optcom = "".
if not chk15_quoteapproval then edt95_optcom = edt95_optcom + "DUE TO
chr05_model + " Base, $" + string(dec05_modelbaseprice) + '~n'. Else
edt95_optcom.
if chr05_gendesc <> "" then edt95_optcom = edt95_optcom + "Generator
if cmb05_voltage <> "" then edt95_optcom = edt95_optcom + "Voltage: "
edt95_optcom.
then edt95_optcom = edt95_optcom + "KW: " + string(dec05_kw) + ","
+ '~n'.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
end
Hope this helps.
John
Norman,
I create a character field, you can display it or not. I then build a
string to that field in an On Leave of another field. Iin this case my
comment field is 'FinOpr3Comments'. I then make a rule to set the
Comment Text = FinOpr3Comments
FinOpr3Comments = (If (FinOpr3 = "Ream Cutting") Then ("Ream Cut
approximately " + String(FinOpr3ShtsPerLift) + " sheets per lift in " +
String(FinOpr3Lift) + " inch lifts" + "~n" + String(FinOpr3CutQtyPer))
Else (""))
The syntax is to enclose plain text in quotes "Ream Cut approximately "
will print exactly as shown.
A + sign indicates to add additional info to the text string (be sure
you place a space before and after the + or it will error)
Reference fields by their field name without quote marks. If you
reference a numeric field you must convert it to a string like
String(FinOpr3ShtsPerLift).
You can place a Line Feed using "~n"
Always put a space before and after your + signs, also include spaces in
your text strings so the spaces are inserted in your comment otherwise
your text will run together.
Good Luck
Todd
Of john_f_01
Sent: Thursday, July 19, 2007 7:29 AM
Subject: [Vantage] Re: 8.03 Product Configurator - Options&Comments
> Norman Hutchins Jr.
Norman,
run PopulateEditor.
edt95_optcom = "".
edt95_optcom.
edt95_optcom.
+ '~n'.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
+ "," + '~n'.
Else
edt95_optcom.
end
Hope this helps.
John
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Ok, back in this topic again, I wish other things didn't keep
popping up so I could concentrate on this subject. I'd like the
thanks everyone who replied back to my questions.
I decided to go with Todd's idea, and I create a character field
(P01_Char_Comments) and I'm using the following two on leave
statements.
If (P01_Logic_PR) = true then do:
P01_Char_Comments = P01_Char_Comments + "This antenna requires
Pattern Review" + "~n".
End.
If (P01_Logic_NF) = true then do:
P01_Char_Comments = P01_Char_Comments + "Null fill of " +
String(P01_Num_NF) + " required for this antenna" + "~n".
End.
When I test the inputs, the text the shows up in the character
field is all on the same line, like it is ignoring the "~n".
Any thoughts?
Norman Hutchins
Use editor box
Of Norman Hutchins
Sent: 27 July 2007 16:40
statements.
End.
End.
Any thoughts?
Norman Hutchins
Norman,
I avoid placing line breaks in my comment strings. The "~n" needs a
space before AND after it. You are ending it with no space and a period.
String the whole statement on one line without breaks in you it and it
will work.
Todd
Of Norman Hutchins
Sent: Friday, July 27, 2007 11:40 AM
statements.
End.
End.
Any thoughts?
Norman Hutchins
The whole statement is on one line, the do If statements are
different on leaves for two inputs. I try the pace after the
"~n) but that didn't help either. They just keep running
together.
What is the editor box???
Thanks again for all the help,
Norman
When you have your Toolbox open when creating your screens, there's an option
for a label, character, decimal, etc. and if you look down further, you'll see
an Editor Box. This is a multi-line box where a character field is a single
line.
Mark W.
job comments.
Thanks.
Mark Tellefson
Rapat Corporation
> > Norman Hutchins Jr.
> Norman,
and
> run PopulateEditor.
> edt95_optcom = "".
TO
Else
> edt95_optcom.
+ "Generator
+ "Voltage: "
> edt95_optcom.
> + '~n'.
> Else
> edt95_optcom.
> + "," + '~n'.
> Else
> edt95_optcom.
> Else
> edt95_optcom.
> + "," + '~n'.
> Else
> edt95_optcom.
> + "," + '~n'.
> Else
> edt95_optcom.
> end
> Hope this helps.
> John
