8.03 upgrade: Error - "Unable to open parameter file "
> Im working on a 8.03 install/conversion.
> I restored the db to the test folder, checked indexes, etc.
> Upon running the 8.03 schema change icon, I receive this error:
> ** Unable to open parameter file C:\CLIENT~1\config\mfgtest.pf, errno
> the only thing in the config folder is mfgsys.ini
> any ideas? support is closed now and Im working a bit later on this.
Did you add Unicode support? I got this error too and I just copied the .pf
files from another location (the server/config folder IIRC). But if you did
enable Unicode support, make sure to add the switches outlined in the
direction.
Mark W.
Thanks!
