Thanks, UD20.Number07 is actually the sequence number as a numeric,
which maintains the correct sequence. I had the field label assigned
as "Sort Order" in the BAQ, but had it hidden in the grid view for
some reason.
Kirstin
some reason.
Kirstin
--- In vantage@yahoogroups.com, "Steve_E" <vantage@...> wrote:
> Kirstin,
> I noticed that the grid view did not display the correct sequence
due to how
> the grid sorts the Sequence number. I edited your new load report
and made
> a calculation field to add the zeros ahead of the lower numbers to
make it
> sort in order.
> Steve
> -----Original Message-----
> From: kirstin.brandt [mailto:kirstin.brandt@...]
> Sent: February 05, 2009 5:11 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: 8.803.407 Engineering BOM levels question
> Pam -
> I ended up having to fill UD20 with the results from the
> EngWorkBenchService.ViewCosts method in order to get the level (it
also
> returns a BOM Sequence field which can be used to keep your BOM in
> order). I saved a copy of the customization in the Files section
under
> Vantage 8.x Customizations - IndentedBOM.zip if you want to take a
look
> at it.
> Kirstin
> P.S. Many thanks to bw for the original customization! It saved me
> TONS of time!
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
> "Lindquist, Pam" <plindquist@> wrote:
> > Does anyone know if there is a field in a table such at PartMtl
that
> > tells us what level a required material is within a BOM
> > Example - a part has 2 manufactured parts and 6 purchased
components.
> > The 2 manufactured parts have their own components.
> > Where is the level number of a BOM material identified?
> > We are trying to build an indented BOM report an avoid looping
through
> > the partmtl table over and over again.
> > Thanks,
> > Pam
> > Metro
