When setting up a blank databse in Vantage 8.03 you need to log into
the database admin tools using a blank username and password, once you
login it will set the manager password. Also make sure your .pf
and .config files referenced in your vantage shortcut file path, have
the correct database and port settings.
Let me know if this helps,
--- In vantage@yahoogroups.com, "stanchmura" <schmura@...> wrote:
> For testing purposes I was attempting to set up a blank 8.803
> database. Once installed, the first attempt at log on as manager-
> manager returns the following message. "Your dabase codepage does
not
> match your session codepage. Continuing may result in corrupt
data."
> If you click past it, the session is aborted. Does anyone know the
> meaning of this message and how to resolve it?
