804.404A Stops responding
We have experienced the same problem - we are on SQL. We found a root
cause for us was Copy Sales Order. It works sometimes, but other
times it locks up an App server and causes the rest of the App
Servers to eventually stall and it locks up everyone.
The best we could do was to tell the users not to use that function.
Once they stopped using Copy Sales Order that type of stall stopped.
Dave
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> Good morning group, from the Pacific Northwest:
> Several months ago we started receiving "No Servers Available."
After
> this message, I was forced to stop and start the AppServers. This
> immediately resolved the problem, but caused a disruption in
service.
> Recently our database climbed above the 3GB mark, and now the
machines
> receive the "No Servers Available" message, but in addition to
> stopping and starting the AppServers, I'm forced to run a repair on
> the database each time this happens (prostrct repair mfgsys).
> Epicor says there is a bug in the Progress database that OpenEdge is
> working on. I'm tired of waiting for a solid answer from Epicor to
> resolve this now. I just seem to get the run around.
> I've increased the AppServer's pool, verified the server is running
> with enough memory, and verified customizations aren't interfering.
> Epicor and I have throughly examined the log files with no success.
> Any help would be greatly appreciated.
> Many Regards,
> --sf
Several months ago we started receiving "No Servers Available." After
immediately resolved the problem, but caused a disruption in service.
Recently our database climbed above the 3GB mark, and now the machines
Many Regards,
--sf
We had the exact same problem. What we found was that our backups were
causing the problem. We had backups scheduled to run at noon, and at 7
PM each day. Right at noon, we would receive that error, and it would
clear up at 12:02. We turned off our noon backup, and haven't had
that problem since.
Of sanfranc415
Sent: Friday, June 27, 2008 10:41 AM
Subject: [Vantage] 804.404A Stops responding
Many Regards,
--sf
that problem since.
Of sanfranc415
Many Regards,
--sf
Our backup runs at 2:00AM, and this problem occurs usually when
the MES users start the clock in and out.
--sf
> that problem since.
> Of sanfranc415
> Many Regards,
> --sf
After spending several hours one-on-one with Epicor after several
weeks or months, I found a solution...
Dump n Load. This is something Epicor never recommened, but I
finally decided to take on the 12+ hour process, which has totally
optimized our database!
Where it took up to 1-minute to load the software, it now only take
20 seconds.
Very excited to have finally find a solution.
Much regards,
--sf
> --sf
backups were
and at 7
it would
had
> > that problem since.
Behalf
> > Of sanfranc415
After
service.
machines
on
is
running
interfering.
success.
> > Many Regards,
> > --sf
I cannot imagine it being a 12+ hour process. With a 3 GB database it should not take more than a couple of hours, with most of that being computer time. I do suppose this would be dependent upon the configuration of your server. I run a 64 bit server with 32 GB of memory and 15K SCSI drives, the database is about 4 ½ GB and the dump and load takes less than 2 hours. Even on my old 32 bit server it did not take that much longer.
I do a dump and load at least every quarter and a re-indexing more often if need be. With the blank database in place the procedure can start with the dump (Keep a copy of that blank database from the 1st time you do the dump). Then straight to the load and indexing. Copy the database over and start it. Then add the users needed for ODBC and set the authority. All done and ready to go. I have done this at least 10 times now without any issues and I have never spent even close to 12 hours.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415
Sent: Wednesday, July 16, 2008 3:35 PM
Subject: [Vantage] Re: 804.404A Stops responding
20 seconds.
Much regards,
--sf
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "sanfranc415" <sanfranc415@...> wrote:
> --sf
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Matt Caldwell" <matt@> wrote:
backups were
and at 7
it would
had
> > that problem since.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf
> > Of sanfranc415
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
After
service.
machines
on
is
running
interfering.
success.
> > Many Regards,
> > --sf
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
I'll have to do a better job of timing next time. I'm sure it took
less than 12-hours, a lot of that time was probably idle time waiting
for the next command.
Ever 3-months is a good marker. I'm still disappointed that Epicor's
techs didn't make this a priority instead of claiming the OpenEdge
Progress database had a bug.
--sf
close to 12 hours.
> 20 seconds.
> Much regards,
> --sf
> > --sf
> backups were
> and at 7
> it would
> had
> > > that problem since.
> Behalf
> > > Of sanfranc415
> After
This
> service.
> machines
> on
OpenEdge
> is
to
> running
> interfering.
> success.
> > > Many Regards,
> > > --sf
> DISCLAIMER:
e-mail immediately.
Gents,
This is interesting reading. Are you on Progress or SQL ?
thanks
kind regards
Debbie Stokes
This email is intended for the addressee only and may contain information that is privileged and confidential. If you are not the intended recipient, you must not copy, distribute or take any
action in reliance on it. If this email has been sent to you in error, please notify us immediately by telephone.
This has been transmitted by -
Hilo-PSS Group
Murdock Road
Dorcan Industrial Estate
Swindon
SN3 5HY
Company Registration No: 01028915.
The views within this email are those of the author and not
necessarily those of Planned Storage Systems Ltd.
** This email has been scanned for viruses, vandals and malicious content **
Running Progress.
--sf
--- In vantage@yahoogroups.com, "Debbie Stokes" <debbie.stokes@...>
wrote:
> Gents,
> thanks
> kind regards
> Debbie Stokes
> Hilo-PSS Group
> Murdock Road
> Swindon
> SN3 5HY
content **
Crashed Again! Our database is 3GBs and have approximately 30-35 4GL
users connected. OpenEdge 10.1B
I'd like to know what members would suggest for the "Maximum
servers:" and "# Blocks in DB Buffer"
Our server is running SBS w/ Exchange, Sharepoint, WSUS, and IIS (low
usuage).
We are running a Quad Xeon 3 Ghz w/ 4Gs of memory.
--sf
> Running Progress.
> --sf
> --- In vantage@yahoogroups.com, "Debbie Stokes" <debbie.stokes@>
> wrote:
> > Gents,
> > thanks
> > kind regards
> > Debbie Stokes
> > Hilo-PSS Group
> > Murdock Road
> > Swindon
> > SN3 5HY
> content **
The plot sickens....
Some sort of search/indexing service crawling the server causing the
issue??
4GL
(low
> usuage).
> Thanks,
> --sf
> --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@> wrote:
> > Running Progress.
> > --sf
> > wrote:
> > > Gents,
> > > thanks
> > > kind regards
> > > Debbie Stokes
the
> > > Hilo-PSS Group
> > > Murdock Road
> > > Swindon
> > > SN3 5HY
malicious
> > content **
Vantage would hang for us about once a week. It would happen only when the
user would try to save a record. The status bar would just read "Saving
Data." Other users would be able to search for information but never save.
We would have to restart the Vantage app servers for it to work again, or if
we waited exactly 30 min, Vantage would kick back in and the records would
be saved. It was a very big problem for us. Support blamed our antivirus
on the server, so we disabled it, and it still happened. They blamed our
ODBC reports, but that wasn't it. For the past two months, every night we
have been removing ALL the stale user sessions found in the Vantage Admin
tools and we haven't had a problem since. We aren't sure if that was the
problem or not, but Vantage has been running without crashing, so you might
want to try that.
Daniel Laidig
Laidig Systems, Inc.
(574) 256-0204 ext. 229
<mailto:daniellaidig@...> daniellaidig@...
_____
sanfranc415
Sent: Friday, July 18, 2008 1:31 PM
usuage).
--sf
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
> Running Progress.
> --sf
> wrote:
> > Gents,
> > thanks
> > kind regards
> > Debbie Stokes
> > Hilo-PSS Group
> > Murdock Road
> > Swindon
> > SN3 5HY
> content **
How do you know it's a stale session? Sometimes it's very obvious,
but other times it's not as obvious.
--sf
--- In vantage@yahoogroups.com, "Daniel Laidig" <daniellaidig@...>
when the
read "Saving
never save.
again, or if
records would
antivirus
blamed our
night we
Admin
was the
you might
> want to try that.
> Daniel Laidig
> _____
Behalf Of
> sanfranc415
4GL
(low
> usuage).
> Thanks,
> --sf
> > Running Progress.
> > --sf
> > wrote:
> > > Gents,
> > > thanks
> > > kind regards
> > > Debbie Stokes
the
> > > Hilo-PSS Group
> > > Murdock Road
> > > Swindon
> > > SN3 5HY
malicious
> > content **
You have too much on that box, Exchange, sharepoint should NOT be running on the
same machine as vantage with more than 10-15 vantage users.
You also don't have enough RAM in the machine for all that you want to run. Max
servers and DB Buffer blocks aren't going to do you any good since you don't
have the physical resources available to actually allocate more resources to it.
sanfranc415
usuage).
--sf
> Running Progress.
> --sf
> wrote:
> > Gents,
> > thanks
> > kind regards
> > Debbie Stokes
> > Hilo-PSS Group
> > Murdock Road
> > Swindon
> > SN3 5HY
> content **
> usuage).
I agree with TechnoB. That's a nice machine for SBS w/Exchange, Sharepoint,
WSUS and IIS ***OR*** Vantage but not both.
Yeah, I know money doesn't grow on trees but you'd be a lot happier if you
added a standalone server for Vantage. (This is a valid SBS configuration.
Any other servers can't be ActiveDirectory servers in an SBS environment but
you can add multiple stand-alone servers. We also have a Terminal Server for
remote access and (soon) our Epicor Portal. And if you get the Enterprise
Edition of Windows (or 64-bit), you'll be able to add/utilize more than 4GB
of memory for Vantage.
Mark W.
Yeah, we would have to purchase another Windows Server w/ 50 licenses
to quickly resolve any performance issues, and I'm trying to avoid
that, but if we clearly determine it's a performance issue, we will
upgrade to SBS 2008 (coming out in November '08) and add at least
16GB of memory.
The App Servers are still acting unusual, 15 app servers are spawned
and hang for no apparent reason.
What experience do people have running Vantage/Progress on Linux OS?
Do we need to purchase Vantage all over again? I guess calling our
salesrep would quickly answer this question.
Regards,
--sf
(low
> > usuage).
Sharepoint,
if you
configuration.
environment but
Server for
Enterprise
than 4GB
> Mark W.
We had this same issue, and found that it happened when our backups
would run. Right at noon each day, the backups would start, and
immediately use all 20 servers. 2 minutes later, it was back to
normal. We disabled that noon backup, and have not had an issue since.
Of sanfranc415
Sent: Friday, July 18, 2008 1:39 PM
16GB of memory.
Regards,
--sf
(low
> > usuage).
Sharepoint,
if you
configuration.
environment but
Server for
Enterprise
than 4GB
> Mark W.
On Linux, OE10.1B would run as a 64 bit app......
Good question though, what about the installation media....
licenses
> 16GB of memory.
spawned
OS?
> Regards,
> --sf
IIS
> (low
> > > usuage).
> Sharepoint,
happier
> if you
> configuration.
> environment but
> Server for
> Enterprise
more
> than 4GB
> > Mark W.
I disagree...your Vantage server would be a member server and you don't
have to buy the licenses for the users accessing it! Just get a server
with the min CALS that it comes with and it will still work.
That is what we have on our network (SBS w/Exchange, etc, and a separate
server for Vantage) and it works fine. And you are not violating any
license agreements with Microsoft - unless it changed in the past year.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of sanfranc415
16GB of memory.
Regards,
--sf
(low
> > usuage).
Sharepoint,
if you
configuration.
environment but
Server for
Enterprise
than 4GB
> Mark W.
