9.0 Client on Dual Core and Hyperthreading Processors
I don't think there would be much benefit to writing multi-processor
support into the Vantage client. Multi-processor (multi-threaded)
applications usually need to do several calculation intensive tasks at
the same time. They break the tasks up and create multiple threads that
get equal time with each of the CPU's. There should be nothing CPU
intensive about any of the "User" functions of Vantage (other than
loading .NET). How would you distribute the load between processors for
entering an order line or a job or a part? It doesn't make sense to do
it. I'm sure MRP would benefit but I believe that is already run on the
server side (disclaimer: just an example - we don't use MRP so I don't
know).
It is not as easy as just "turning on" support for multiple processors.
The application has to be written to take advantage of them and there
has to be a good reason to write parts of the application that way in
the first place.
Chris Gitzlaff
Major Industries
megensel wrote:
> I'm surprised that it has not been programed in. I have software
> that's 5+ years old that has support for multiprocessors. It makes
> more sence to me that it would just be something that has to
> be "turned on". Does anyone have direct knowledge that the client
> doesn't support Multiple processors?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>,
> "David Gartner" <dgartner@...> wrote:
> > Not to hijack, but I wonder if "Epicor 9" will be developed and
> complied for
> > multiple processor support?
> > _____
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>] On
> Behalf Of
> > Ted Kitch
> > Sent: Thursday, March 13, 2008 10:49 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: RE: [Vantage] Re: 8.03 Client on Dual Core and
> Hyperthreading
> > Processors
> > It has to be developed and compiled with multiple processor support
> in order
> > to utilize multiple processes (processors). What Michael said is
> 100% true.
> > Vantage/Vista runs as a single process and there is nothing that
> can be
> > reasonably done from the user end to change that. Epicor would need
> to
> > release a client that supports multiple-processors. That means you
> can have
> > as many processors or cores on a client computer, but Vantage/Vista
> is only
> > going to use one of them.
> > HTH,
> > Ted Kitch
> > Information Technology Manager
> > Astro Machine Corporation
> > www.astromachine.com
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > [mailto:vantage@yahoogroups <mailto:vantage%
> 40yahoogroups.com> .com] On
> > Behalf Of
> > megensel
> > Sent: Thursday, March 13, 2008 10:30 AM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > Subject: [Vantage] Re: 8.03 Client on Dual Core and Hyperthreading
> > Processors
> > I understand that it runs as a single "process", what I am asking
> is
> > how to make the program realize that there are two processors and
> to
> > utilize them both instead of just one at a time.
> > --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > <mailto:vantage%40yahoogroups.com> , "Michael
> > Barry" <mbarry@> wrote:
> > > The Vista/Vantage client runs within the context of a single
> > process.
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > <http://www.aspacia <http://www.aspacia.com/
> <http://www.aspacia.com/>> com/>
> http://www.aspacia
> > <http://www.aspacia.com/ <http://www.aspacia.com/>> com/
> > [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of
> > > megensel
> > > Sent: Thursday, March 13, 2008 7:25 AM
> > > Subject: [Vantage] 8.03 Client on Dual Core and Hyperthreading
> > Processors
> > > I dont know if this question has been ask or the problem noticed
> > > before, but I have noticed that the Vista client only seems to be
> > using
> > > one processor when it runs. I assume that this would be a
> > performace
> > > problem and I wonder if anyone has run into it. I have seen other
> > > programs that do not have multiprocessor support turned on for
> > various
> > > reasons and you need to run a switch on the shortcut to activate
> it
> > but
> > > I can find no such switch for vista... So if anyone has any ideas
> I
> > > would musch appreciate your input.
> > > Mike Gensel
> > > Web Application Developer / IT
> > > michaelg@ <mailto:michaelg%40livoniatool.com>
> > <http://geo.yahoo.com/serv? <http://geo.yahoo.com/serv?>
> s=97359714/grpId=20369/grpspId=1705007183/msgId=6
> > 3286/stime=1205423345/nc1=4507179/nc2=3848640/nc3=5202323>
before, but I have noticed that the Vista client only seems to be using
one processor when it runs. I assume that this would be a performace
programs that do not have multiprocessor support turned on for various
reasons and you need to run a switch on the shortcut to activate it but
I can find no such switch for vista... So if anyone has any ideas I
Mike Gensel
michaelg@...
The Vista/Vantage client runs within the context of a single process.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
megensel
Subject: [Vantage] 8.03 Client on Dual Core and Hyperthreading Processors
Mike Gensel
michaelg@... <mailto:michaelg%40livoniatool.com>
I understand that it runs as a single "process", what I am asking is
how to make the program realize that there are two processors and to
process.
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
Behalf Of
> megensel
Processors
using
performace
various
but
> Mike Gensel
It has to be developed and compiled with multiple processor support in order
to utilize multiple processes (processors). What Michael said is 100% true.
Vantage/Vista runs as a single process and there is nothing that can be
reasonably done from the user end to change that. Epicor would need to
release a client that supports multiple-processors. That means you can have
as many processors or cores on a client computer, but Vantage/Vista is only
HTH,
Ted Kitch
megensel
Processors
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Michael
process.
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
Behalf Of
> megensel
Processors
using
performace
various
but
> Mike Gensel
Not to hijack, but I wonder if "Epicor 9" will be developed and complied for
_____
Ted Kitch
Subject: RE: [Vantage] Re: 8.03 Client on Dual Core and Hyperthreading
Processors
HTH,
Ted Kitch
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
megensel
Processors
process.
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> <http://www.aspacia <http://www.aspacia.com/> com/> http://www.aspacia
Behalf Of
> megensel
Processors
using
performace
various
but
> Mike Gensel
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msgId=6
complied for
> _____
Behalf Of
> Ted Kitch
Hyperthreading
> Processors
in order
100% true.
can be
to
can have
is only
> HTH,
> Ted Kitch
> Behalf Of
> megensel
> Processors
is
to
> process.
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
http://www.aspacia
> Behalf Of
> > megensel
> Processors
> using
> performace
> various
it
> but
I
> > Mike Gensel
