9.04.504B Cannot print Physical Inventory Variance Report
vantage@yahoogroups.com wrote:
> Is this the case for 8.03.407 series. I have ###.407C.
The cycle count system is different in Epicor 9 - so I would guess not. I
would highly recommend testing it before hand!
Mark W.
Just an FYI for those coming up on a physical inventory, we have found that
we cannot run the Count Variance report. Running from the Developer gives an
"Out of Memory" condition. It will not preview and will not export or print
directly to the printer. Epicor was able to duplicate. We had less than 5000
tags in a single plant.
Mark W.
> found that we cannot run the Count Variance report. Running from the
> Developer gives an "Out of Memory" condition. It will not preview and
> will not export or print directly to the printer. Epicor was able to
> duplicate. We had less than 5000 tags in a single plant.
Apparently, this is a known issue and will be fixed in 9.04.506.
Our developers have reviewed this and have attached this call to an
existing SCR - SCR 64148. This SCR had already been created for a
similar, related issue. Once that SCR is fixed, this issue should be
resolved.
Presently this SCR is targeted to the 506 SP.
So you're going to do a complete physical inventory at the end of the year
in Epicor 9 and you have more than a few thousand tags, the fix won't be
ready in time. We created a BAQ that combined the CCTag and CCDtl tables to
download into Excel to determine count variances.
Mark W.
Of Mark Wonsil
Sent: Wednesday, November 11, 2009 12:06 PM
Subject: RE: [Vantage] 9.04.504B Cannot print Physical Inventory
Variance Report
resolved.
year
to
Mark W.
