9.04->9.05 Upgrade crashes out when running last convertion
We do have the CRM module so will take a look thanks.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> I notice the "Customer.ShipToTerrList" bit... in our first conversion to
> 9.05 database we got several error message about CRM module related
> stuff not setup properly when we tried to enter an order. We had to do
> the setup in company maintenance (for options we don't use) and run
> conversion program 6880. We also had several customers without a
> territory selected (in Vantage 6.1) which we also fixed.
> Just a guess, but might be worth a look if you have the CRM module.
> Brian.
> -----Original Message-----
> Of Zac Jason Woodward
> Sent: Thursday, May 12, 2011 12:40 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] 9.04->9.05 Upgrade crashes out when running last
> convertion
> The only thing I can think of is you have missed one of the manual
> required conversions at 9.04
> Sent from my Verizon Wireless 4GLTE smartphone
> ----- Reply message -----
> From: "markbetts66" <markbetts66@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Subject: [Vantage] 9.04->9.05 Upgrade crashes out when running last
> convertion
> Date: Thu, May 12, 2011 1:21 am
> Hi,
> we are trying to upgrade our Epicor 9.04.507 (SQL) installation to
> Epicor 9.05.604A (SQL) to test the performance over 8.03.408 (SQL). All
> goes well except on the LAST (grrr) mandatory data conversion program
> (CVCR0024.p, Fix the values on Customer.ShipToTerrList) the program
> throws up the following error:
> * DataServer Cache Error - No data available (3631)
> then the appserver helpfully causes a general exception in windows and
> crashes :(
> Has anyone else had this issue or is the a way I can do the change
> myself?
> Thanks for any help,
> Mark.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi,
we are trying to upgrade our Epicor 9.04.507 (SQL) installation to Epicor 9.05.604A (SQL) to test the performance over 8.03.408 (SQL). All goes well except on the LAST (grrr) mandatory data conversion program (CVCR0024.p, Fix the values on Customer.ShipToTerrList) the program throws up the following error:
then the appserver helpfully causes a general exception in windows and crashes :(
Has anyone else had this issue or is the a way I can do the change myself?
Mark.
The only thing I can think of is you have missed one of the manual required conversions at 9.04
Subject: [Vantage] 9.04->9.05 Upgrade crashes out when running last convertion
Hi,
Mark.
Brian.
convertion
convertion
Hi,
crashes :(
myself?
Mark.
