9.05.601 Service Pack
The 9.05.601 Service Pack is out.
Just to give anyone a heads up, the install package has changed, it now does
a version check of OpenEdge, Crystal, Windows etc to make sure you can apply
it to the server you are installing it on.
Also, there is a Service Pack 3 for OpenEdge 10.2A, along with a hot fix 9
for it as well, these are checked for in the 601 SP along with Crystal
Runtime which is moved up to Crystal 2008 SP 3.
Thanks for the information. Does the service pack install the temporary files
by default on the C drive or do you have an opportunity to select another drive?
thanks
Sent: Sat, September 25, 2010 1:18:42 AM
Subject: [Vantage] 9.05.601 Service Pack
Â
