Bumping this from the weekend. Does anyone have suggestions?
Sent: Monday, May 28, 2012 2:04 PM
Subject: 9.05.700A STD Costs Adjustment Requires Lotnum
I am working towards go live and recently changed purchased parts from FIFO to LOT FIFO, so I could see the lot numbers in the FIFO Costs. I was advised by support that FIFO also showed the lot number on the costs buckets in 700, but it did not after I upgraded.
Now when I am loading Standard Material Costs thru DMT or the client, a lot number is required.
Is there a work around for this? A setup I have wrong?
I need to load standard cost for all of our items, so I may have to go back to FIFO.
Thanks for any advice.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Greg Payne
