9.05.700B BPM Email
Thank you Brenda! It worked perfectly.
I am trying to get the BPM email code to work and not having much luck. Done a lot of searching here and got the answerbook help, but still no luck. Take a look to see if I have everything right. If so, then what services do I need to have turned on to let the email go? If not, please help.
Thanks in advance.
for each ttOrderHed
                where
ttOrderHed.RowMod = ‘U’ on error undo, next:
                define
variable vFrom as character no-undo initial ‘’:U.
                define
variable vTo as character no-undo initial ‘’:U.
                define
variable vCC as character no-undo initial ‘’:U.
                define
variable vSubject as character no-undo initial ‘’:U.
                define
variable vBody as character no-undo initial ‘’:U.
                define
variable hEmailEx as handle no-undo.
                run
Bpm/BpmEmail.p persistent set hEmailEx.
                define
variable vMsg as character no-undo initial ‘’:U.
                define
variable from_cnt as integer no-undo.
                define
variable to_cnt as integer no-undo.
                define
variable cc_cnt as integer no-undo.
                define
variable subject_cnt as integer no-undo.
               define
variable body_cnt as integer no-undo.
                 assign
vBody = ‘Hello’.
                assign
vSubject = ‘Monte Test’.
                assign
vFrom = me@…’.
                assign
vTo = me@…’.
                if
valid-handle(hEmailEx) then
                RUN
SendMail in hEmailEx (FALSE, CUR-COMP, vFrom, vTo, vCC, vSubject, vBody,
“”:U).
                {lib/PublishInfoMsg.i
&InfoMsg = vSubject}.
                 if
valid-handle(hEmailEx) then DELETE PROCEDURE hEmailEx.
                LEAVE.
end.
For what is worth there are a dozen or more threads on this specific topic in the forum. Search around a bit and you'll likely find your answer.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Tue, Aug 5, 2014 at 3:53 PM, mtisland@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span></span></p><p>I am trying to get the BPM email code to work and not having much luck. Done a lot of searching here and got the answerbook help, but still no luck. Take a look to see if I have everything right. If so, then what services do I need to have turned on to let the email go? If not, please help.</p>
Thanks in advance.
for each ttOrderHed
               where
ttOrderHed.RowMod = 'U' on error undo, next:Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
               define
variable vFrom as character no-undo initial '':U.
               define
variable vTo as character no-undo initial '':U.
               define
variable vCC as character no-undo initial '':U.
               define
variable vSubject as character no-undo initial '':U.
               define
variable vBody as character no-undo initial '':U.
               define
               run
               define
variable vMsg as character no-undo initial '':U.
               define
               define
               define
               define
              define
                assign
vBody = 'Hello'.
               assign
vSubject = 'Monte Test'.
               assign
vFrom = me@…'.
               assign
vTo = me@…'.
               if
               RUN
"":U).
                if
               LEAVE.
Â
end.
</div>
<div style="color:#fff;min-height:0;"></div>
Here is my template.  It is plug in ready.
DEFINE VARIABLE hEmailProc AS HANDLE NO-UNDO.
RUN Bpm/BpmEmail.p PERSISTENT SET hEmailProc.
DEFINE VARIABLE emailFrom AS CHARACTER INITIAL "email@removed" NO-UNDO.
DEFINE VARIABLE emailTo AS CHARACTER INITIAL "email@removed" NO-UNDO.
DEFINE VARIABLE CCTo AS CHARACTER INITIAL "" NO-UNDO.
DEFINE VARIABLE subject AS CHARACTER INITIAL "SUBJECT" NO-UNDO.
DEFINE VARIABLE emailBody AS CHARACTER INITIAL "EMAIL BODY" NO-UNDO.
emailTo = " email@removed ".
Subject = "My Subject".
emailBody = "Hello World".
RUN SendEmail IN hEmailProc (
false,                      /*Async*/
"10",                       /*Company*/
emailFrom,           /*Email From*/
emailTo,                /*Email To*/
CCTo,                    /* CC*/
subject, /*Subject*/
emailBody,           /*Text*/
''                               /*MIME Type*/
IF VALID-HANDLE(hEmailProc) THEN DELETE PROCEDURE hEmailProc NO-ERROR.
Brenda
Sent: Tuesday, August 05, 2014 3:53 PM
Subject: [Vantage] 9.05.700B BPM Email
Thanks in advance.
for each ttOrderHed
                where ttOrderHed.RowMod = 'U' on error undo, next:
                define variable vFrom as character no-undo initial '':U.
                define variable vTo as character no-undo initial '':U.
                define variable vCC as character no-undo initial '':U.
                define variable vSubject as character no-undo initial '':U.
                define variable vBody as character no-undo initial '':U.
                define variable hEmailEx as handle no-undo.
                run Bpm/BpmEmail.p persistent set hEmailEx.
                define variable vMsg as character no-undo initial '':U.
                define variable from_cnt as integer no-undo.
                define variable to_cnt as integer no-undo.
                define variable cc_cnt as integer no-undo.
                define variable subject_cnt as integer no-undo.
               define variable body_cnt as integer no-undo.
                 assign vBody = 'Hello'.
                assign vSubject = 'Monte Test'.
                assign vFrom = me@...'.
                assign vTo = me@...'.
                if valid-handle(hEmailEx) then
                RUN SendMail in hEmailEx (FALSE, CUR-COMP, vFrom, vTo, vCC, vSubject, vBody, "":U).
                {lib/PublishInfoMsg.i &InfoMsg = vSubject}.
                 if valid-handle(hEmailEx) then DELETE PROCEDURE hEmailEx.
                LEAVE.
end.
