The Error relates to an invalid TaxCatID
Unfortunately in DMT we have to utilise the business objects errors and these often use the label values for fields.
Are you specifying a valid entry for this column?
If the issue still persists please provide your Epicor Version, DMT Version or drop this to support and they will help resolve.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Sent: 28 May 2013 19:56
Subject: Re: [Vantage] Re: 9.05.701 DMT Import Error
For DMT errors I usually recommend hiring a translator. lol !
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Joshua Giese
CTO
----- Original Message -----
From: "Michael" <mkgross69@...<mailto:mkgross69%40gmail.com>>
Sent: Tuesday, May 28, 2013 1:53:23 PM
Subject: [Vantage] Re: 9.05.701 DMT Import Error
Kim,
Same problem here a couple of times. Category ID is referring to either Part Class (DMT Column=ClassID) or Product Group (DMT column=ProdCode).
I can't remember which for sure, but I'm pretty sure it's one of those. It's been a few months since my pre-go-live DMTs had errors.
Can't hurt to check those.
Mike
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> , "faepigrl" <faepigrl@...<mailto:faepigrl@...>> wrote:
> I am importing PART table using the DMT. I am getting an error on almost all my records with a message of: Category ID refereneces invalid value.
> I don't have a column called Category ID and don't see one in the DMT as a valid column.
> Does anyone have any ideas?
> Thanks Kim
