I think it's broken in 701. I tried the "set to location" and nothing happened. Also, when I placed a service call with Epicor and told them the problem was with 701 and Progress, I got an immediate response from a tech with the SCR. One of the very few times I didn't have to prove there was a problem!
Sue
Sue
--- In vantage@yahoogroups.com, "Jennifer" wrote:
> Hmmm - wonder if that was something that worked in 607 and broke in 701? Did you ever try clicking the "set to location" once you have the appropriate lines selected to see if it fills it in then?
> --- In vantage@yahoogroups.com, "snielsen28" wrote:
> > Mass Receipts in 9.05.701 has a bug where the warehouse in the PO release isn't always filled automatically in when the receipt is done. The workaround is to manually enter the warehouses in the grid, not fun when you have a PO with a number of lines. SCR 110938.
> > Sue
> > > You can try Options / Mass Receipt. That will show all the lines and you can select the ones you want to receive.
> > > --- In vantage@yahoogroups.com, "Steve" wrote:
> > > > We are in the process over moving from 8.03.410 to 9.05.701 and have found
> > > > that receipt entry does not display the open PO lines in tree view. Is this
> > > > now gone or am I missing something?
> > > > [Non-text portions of this message have been removed]
