9.05 Install on 64bit system
Haven't done a dump and load (yet). I am doing the restore to a blank (deleted any existing files) location. Still end up with the error. What's interesting is the b1 goes from 8k to 256k when it fails. I'm using the exact procedure to restore to the 32bit install and I have no issues. I can restore the 32bit 905 db that's been truncated and through the schema change to the 64bit box and it will run fine but the truncate still fails.
I'm going to try the dump and load and see if I get any further.
--- In vantage@yahoogroups.com, Zac Jason Woodward <zac@...> wrote:
> Are you doing a dump and load? Are you restoring into the existing empty DB?
> If you are not doing a dump and load and you are trying to restore your DB to the empty DB you will get this error as the block sizes are mismatched. If this is your case stop the DB services and delete the empty DB. After that run your restore and it will create the DB with your data, instead of restoring into an existing DB.
> "Zac" Jason Woodward
> Network Administrator
> Intermountain Electronics, Inc.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Creating customer confidence through extraordinary service and experienced industry experts.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cmulford_66
> Sent: Wednesday, July 06, 2011 7:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] 9.05 Install on 64bit system
> Having an issue with Progress install on a 64bit system. I cannot get the database (restored from patched 9.04) to truncate. I get a "_dbutil.exe has stopped working". I have no issues doing this process on a 32bit server with 9.05. Epicor tech hasn't a clue. Anyone run across this one?
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
