905.605 Install issue
Just an FYI, don't use a regular workstation for the schema and DB
conversions.
I assume you have installed the 64-bit version of 9.05 with 64-bit OpenEdge,
if not and you are still going to use the 32-bit version of Epicor 9.05 then
you should still be able to run the schema and conversions on that server.
You should install the 32-bit version of OpenEdge on another server,
preferably one connected to the same switch as your Epicor Server. Running
it from a standard windows workstation will kill your performance and add an
incredibly high amount of time to your whole process.
Paul Lipham
Sent: Friday, July 01, 2011 2:39 PM
Subject: RE: [Vantage] Re: 905.605 Install issue
If you start to upgrade a test database from 904 to 905 you need to call
support first. We tried with their installation guide for a week with no
results, then the guy in Epicor Tech Support started helping and basically
nothing he told us to do was in the install/upgrade guide. We are upgrading
this weekend and have to do the entire schema change and DB conversions on a
32 bit Windows client, because our server is X64. It kind of stinks not to
be able to use the horsepower of the new kicking DB server to upgrade the
DB.
They also have a new install guide that was updated last Friday. Make sure
you get that one.
Paul L.
David G
Sent: Tuesday, June 28, 2011 7:04 AM
Subject: [Vantage] Re: 905.605 Install issue
That worked thanks for the advise.
Little worried on how well 605 will run in general if they can't even get
the install package to work without tweaks.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Gary
Parfrey <garyp@...> wrote:
> Unzip the releaseclient.zip in the Epicor905 directory and copy the
contents into the epior905\client folder.
> I suggest you make a copy of the client folder first
> Gary
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of David G
> Sent: 27 June 2011 21:35
> Subject: [Vantage] 905.605 Install issue
> Trying to install Epicor 905.605 on a new Windows 2008 R2 SP1 64 bit
VM.I've had the following issue with the 32-bit and 64 bit version of
Epicor.
> I install 9.05 (no HF or SP), and I am able to open the client. I install
the 605 SP and when I open the client on the server it tells me MFGSYS.exe
is missing. Also Admin Tools, and Schema Change will not open. I get no
errors on the installs and it looks like it completes. Also If I try to run
the client from a 32-bit Win 7 machine I get a slew of errors that would
require a screen shot. I've tried calling support a couple of times but all
I get is the voicemail box after being on hold for 10 minutes.
> Anyone have any idea's.
Trying to install Epicor 905.605 on a new Windows 2008 R2 SP1 64 bit VM.I've had the following issue with the 32-bit and 64 bit version of Epicor.
I install 9.05 (no HF or SP), and I am able to open the client. I install the 605 SP and when I open the client on the server it tells me MFGSYS.exe is missing. Also Admin Tools, and Schema Change will not open. I get no errors on the installs and it looks like it completes. Also If I try to run the client from a 32-bit Win 7 machine I get a slew of errors that would require a screen shot. I've tried calling support a couple of times but all I get is the voicemail box after being on hold for 10 minutes.
Unzip the releaseclient.zip in the Epicor905 directory and copy the contents into the epior905\client folder.
Gary
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of David G
Little worried on how well 605 will run in general if they can't even get the install package to work without tweaks.
> Gary
If you start to upgrade a test database from 904 to 905 you need to call support first. We tried with their installation guide for a week with no results, then the guy in Epicor Tech Support started helping and basically nothing he told us to do was in the install/upgrade guide. We are upgrading this weekend and have to do the entire schema change and DB conversions on a 32 bit Windows client, because our server is X64. It kind of stinks not to be able to use the horsepower of the new kicking DB server to upgrade the DB.
They also have a new install guide that was updated last Friday. Make sure you get that one.
Paul L.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Gary Parfrey <garyp@...> wrote:
> Gary
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of David G
