Mark did a fantastic job of providing a comprehensive list of pain points. One that really stuck with me is how much manual effort it takes for admins to keep track of what code exists in each environment. That’s where drift creeps in — eventually nobody is 100% sure what’s actually deployed where, or what should be deployed.
At its core, this isn’t a tooling problem so much as a state‑management problem.
What I’m trying to do is a sanity‑check; I want, ideas, comments, roadblocks and general thoughts:
Does explicitly separating intent, expectation, and reality actually line up with how you want to work? And where would this break down in real‑world Kinetic usage?
This isn’t meant as a prescriptive “do this” solution, but as a way to reason about the problem space.
1. Proposed Architecture
Problem framing
- Environment state in Kinetic is non‑deterministic unless it is actively reconciled.
- Any deploy‑only model will fail over time because environments inevitably mutate outside pipelines (UI edits, emergency fixes, cloud‑side actions).
Core principle
- Explicitly separate intent, expectation, and reality.
- Never allow a single artifact to claim to be “the truth.”
Structural solution
A single repository with clearly separated responsibilities:
/projects folder — authoritative deployable units
- Master fork of
/projects — environment‑neutral canonical source
- Environment branches — declared deployed state pointers
- Environment manifests — expected state contracts
- Backup forks — observed reality snapshots
The Project Folder Master Fork
The /projects folder is not a convenience directory; it is a governance boundary.
It contains:
- Script bundles
- Report packages
- Function artifacts
- Any deployable Kinetic unit that can be meaningfully versioned
Critically, /projects is:
- Environment‑agnostic
- Credential‑free
- Free of environment assumptions
- Ignored by kinetic_devops, so local experimentation cannot mutate deployable state
This allows /projects to function as a pure artifact registry, not a working directory.
The master fork (or protected branch) of /projects is the only source from which Training and Production promotions are allowed to occur. No environment may receive anything that does not already exist here.
It defines:
- What can exist anywhere
- What may be promoted
- What is considered reviewable work
Developers do not deploy “their branch” into higher environments. Pipelines deploy approved artifacts. Promotion is a controlled reference move, not a file copy.
Dev as an Integration Environment (Feature Branch CI/CD)
Development environments serve a different purpose than Training or Production: they are integration platforms, not promotion targets.
As such:
- Dev environments may accept deployments from short‑lived feature branches, constrained to
/projects
- Training and Production environments may not
This enables full CI/CD against a real Kinetic target before changes are merged into main, while keeping main continuously releasable.
Feature branch deployments are explicitly non‑authoritative:
- They do not advance promotion pointers
- They do not redefine expected state
- They exist to validate changes prior to merge
Environment‑Driven Deployment Policy
Deployment eligibility is environment‑owned, not pipeline‑hardcoded.
Each environment declares its own deployment policy via secure metadata (e.g., Keyring), such as:
IsProduction
AllowedDeploymentSources (FeatureBranch, Main, ReleaseTag)
Pipelines evaluate this contract rather than embedding branch logic. This allows:
- Dev to accept feature branch deployments
- Training to behave like Prod when desired
- Production to require stricter sources (e.g., signed release tags)
The environment declares what it will accept; the pipeline merely enforces it.
Lifecycle
- Dev work → feature branch under
/projects
- CI → build/test on PR
- Deploy‑to‑Dev → allowed from feature branches (integration testing)
- Merge → PR into
main after Dev validation
- Promote → pipeline deploys from protected
/projects fork
- Validate → environment checks
- Record → environment branch + manifest update
- Observe → explicit pull/export from environment
- Reconcile → diff against master fork and manifests
Invariant
- Humans propose.
- Pipelines promote.
- Environments are observed, not trusted.
Intent, Expectation, Reality
This model deliberately distinguishes three independent states:
- Intent — what we believe should exist, expressed through Git history and review
- Expectation — what an environment contractually claims to contain, expressed through manifests
- Reality — what is actually present, obtained only through observation and export
None of these is allowed to overwrite the others silently.
Environment Branches as Pointers, Not Workspaces
Branches such as env/dev, env/Training, and env/prod do not contain evolving code. They contain references.
They are advanced only by automation, and only after:
- Deployment succeeds
- Validation passes
- The environment is confirmed to match the deployed artifact
They answer a single question:
“What version did we last declare as deployed here?”
They are historical markers, not collaboration surfaces.
Environment Manifests as Contracts
Manifests sit orthogonally to branches.
They describe:
- Expected artifacts
- Expected versions or hashes
- Optional fingerprints of deployed state
They are designed to be violated.
When reality diverges from a manifest, that divergence is surfaced rather than hidden. Drift becomes observable and discussable instead of anecdotal.
Pull, Snapshot, Reconcile (The Non‑Negotiable Half)
The model explicitly supports pulling from environments.
A pull operation:
- Exports the live environment state
- Stores it in a backup fork or protected snapshot branch
- Computes diffs against:
- The environment branch (declared intent)
- The environment manifest (expected state)
- The master
/projects fork (approved artifacts)
Nothing is overwritten. Nothing is “fixed” automatically.
Unexpected changes become evidence, not embarrassment.
Why the Backup Fork Exists
The backup fork is not a rollback mechanism.
It is not a workflow tool.
It is forensics.
It answers:
- “When did this change first appear?”
- “Was this ever reviewed?”
- “Did this exist before promotion?”
In regulated or audit‑sensitive environments, this alone justifies the model.
Resulting Operating Model
- Developers propose changes to
/projects
- Dev environments support CI/CD from feature branches
- Pipelines are the only entities allowed to promote
- Training/Prod deploy only from approved sources
- Environments are continuously observed
- Drift is reconciled explicitly
- State is derived, not assumed
This does not eliminate complexity.
It names it, constrains it, and makes it survivable.
