ABC Codes & Cycle Counting
Bruce:
Afraid we aren't all that clever in what we name the group! We just use the
date with a dash (120704-1), it keeps like groups together that way and it's
easy to find and also to delete the old ones without having to open them up
to see when they were created.
We count every day, sometimes he'll do more than 1 group a day - that might
happen if the first group went quick and maybe there's a new project that we
want/need to keep tabs on, so he'll go ahead and run a second group.
I'm happy to be able to help....
Julie
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, December 08, 2004 7:24 AM
Subject: [Vantage] Re: Re: RE: ABC Codes & Cycle Counting
> Julie,
> I was wondering what you use for a naming scheme for your cycle counts
> (I wish the system would filter the posted counts). Also, do you run
> the counts once / day? Or week? or month?
> Thanks for all your help.
> Bruce
> Message: 2
> Date: Mon, 6 Dec 2004 10:34:32 -0600
> From: "Julie Lehmann" <jlehmann@...>
> Subject: Re: RE: ABC Codes & Cycle Counting
> Bruce:
> Are you trying to set it up to not count the "C" stuff at all? Vantage
> will leave the code, but you could set it up to count "C" items every
> 999 days, or whatever you want. The biggest trick is to get a "counted
> date" into all of those parts first. For instance, if you are planning
> to do a full physical inventory at year-end, that would give all of your
> parts a last counted date and then you should be able to get it working.
> As per my earlier post though, you have to make sure you include all
> warehouses for every item, so if you do a physical, make sure you
> include 0 quantity locations. When we set it up, we ended up doing
> several "Physicals" - one for each and every warehouse separately, so we
> could get those dates in there. That really is the key. Then you can
> set your codes to count with whatever frequency you want and auto-select
> will only bring up the items that are on the right schedule. We have A
> codes set up for 28 days, B codes for 84 days, C codes for 175 days,
> and then I added a D code for 999 days. We've been using it for a year
> now and except for the fact that they have to be sure and include all 0
> quantity locations with the regular cycle count - it works great and we
> actually will not be doing any more physical inventories!
> HTH....
> Julie Lehmann, MIS Director
> MERCURY MINNESOTA INC.
> Bruce Butler, IT Manager
> Knappe & Koester
> 18 Bradco St
> Keene, NH 03431
> bbutler@...
> p.603.355.1166
> f. 603.355.2266
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.289 / Virus Database: 265.4.6 - Release Date: 12/5/2004
We have been manually entering parts from custom reports for cycle
counting. What are your experiences with using the ABC methodology?
Do you count daily?
Thanks for any input,
Bruce
Bruce:
We use Vantage's cycle count process. The ABC's that the system assigns are
okay if you have enough history in the system, and then you can modify the
items that might not be set at the right code. We've been doing it long
enough that we had a pretty good handle on what should be set at which code.
The quirk with using Vantage's cycle counting is that if you have multiple
locations for a part, and there is no quantity of the part in one (or more)
locations, cycle counting doesn't include the zero quantity locations in the
cycle count group for that day, so what happens is the system doesn't think
you really counted that part, so it'll keep coming up day after day. The
work-around for this, (that we have found and use), is we look up the
locations for each part, and if there are locations at zero quantity - we
manually add them back into the cycle count group - that way the system
recognizes it as being counted and the cycle continues correctly. An
example would be a part coming in goes to the "recv whse". That goes
to "0" on hand as soon as they move it to the correct location. So, when
you go to cycle count that part, the "recv whse" doesn't come up to count.
However, if you don't include that warehouse, the "last count" field is not
updated for that part/location and it'll come up again to be counted with
the next cycle group.
Other than that, it works really well and yes, we count daily.
Julie Lehmann
Mercury Minnesota Inc.
Sent: Wednesday, December 01, 2004 1:24 PM
Subject: [Vantage] ABC Codes & Cycle Counting
> Do you count daily?
> Bruce
> Yahoo! Groups Links
Version: 7.0.289 / Virus Database: 265.4.4 - Release Date: 11/30/2004
quite simply abc counting in vantage doesn't work.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Wednesday, December 01, 2004 2:25 PM
Do you count daily?
Bruce
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129dr8353/M=298184.5639630.6699735.3001176/D=gr
oups/S=1705007183:HM/EXP=1102015507/A=2434971/R=0/SIG=11eeoolb0/*http://www.
netflix.com/Default?mqso=60185400> click here
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=
:HM/A=2434971/rand=777135851>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Frank,
We discussed this at Perspectives and I know that you felt that this
functionality was lacking as an inventory management tool. It seems to me
that the combination of ABC codes and cycle counts works well as designed,
it is simply a matter of how a company chooses to define its ABC
classifications. However, I cannot remember your specific criticisms.
Could you elaborate again?
Regards,
Scott Lepley
Systems Administrator
Mauell Corporation
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.514
Sent: Wednesday, December 01, 2004 5:12 PM
Subject: RE: [Vantage] ABC Codes & Cycle Counting
Frank Zeigafuse
General Manager
Do you count daily?
Bruce
when I was in the class in Vegas it wasn't working for the teacher either
but I cannot remember specifically. I looked at this back in 2000.
Frank Zeigafuse
General Manager
Sent: Thursday, December 02, 2004 12:42 PM
To: 'vantage@yahoogroups.com'
Frank,
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Frank Zeigafuse
General Manager
Do you count daily?
Bruce
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129c8mjob/M=298184.5639630.6699735.3001176/D=gr
oups/S=1705007183:HM/EXP=1102095861/A=2434971/R=0/SIG=11eeoolb0/*http://www.
:HM/A=2434971/rand=326705658>
_____
Yahoo! Groups Links
I originally setup two classes. A is for dollar volumes over $2000, and
C was for everything else. I am just experimenting so these figures are
not set in stone. Well, I decided I only wanted the $2000 stuff to get
auto selected. From there I gave C an outlandish (for us anyway) volume
over $10,000 and reassigned with the intention of clearing class codes
for everything except for the A parts. For whatever reason those 'C'
parts do not want to give up their classification.
Therefore, I am in agreement with Frank that the abc counting doesn't
work. I am guessing Vantage wants a code on all parts. I would really
like to get this to work simply because of the time it takes to manually
enter part numbers to get counted.
Knappe & Koester
18 Bradco St
Keene, NH 03431
bbutler@...
p.603.355.1166
f. 603.355.2266
Message: 14
Date: Thu, 2 Dec 2004 16:32:49 -0500
Subject: RE: ABC Codes & Cycle Counting
either
Frank Zeigafuse
General Manager
Frank,
me
designed,
Regards,
Scott Lepley
Mauell Corporation
Fax: 717-432-8688
Email: sal@...
Frank Zeigafuse
General Manager
Do you count daily?
Bruce
I beg to differ...we have been using it for about 5 years...admittedly, we
are a small company and only count once a week or once a month, but we have
not shut down for a complete inventory since October of 98...so I guess it's
all in how you look at it.
Lydia Coffman
Canyon Engineering Products
661-294-0084
Sent: Wednesday, December 01, 2004 2:12 PM
Frank Zeigafuse
General Manager
Do you count daily?
Bruce
ADVERTISEMENT
_____
Yahoo! Groups Links
keyboards
any).
Yahoo! Groups Links
Bruce:
Are you trying to set it up to not count the "C" stuff at all? Vantage will
leave the code, but you could set it up to count "C" items every 999 days,
or whatever you want. The biggest trick is to get a "counted date" into all
of those parts first. For instance, if you are planning to do a full
physical inventory at year-end, that would give all of your parts a last
counted date and then you should be able to get it working. As per my
earlier post though, you have to make sure you include all warehouses for
every item, so if you do a physical, make sure you include 0 quantity
locations. When we set it up, we ended up doing several "Physicals" - one
for each and every warehouse separately, so we could get those dates in
there. That really is the key. Then you can set your codes to count with
whatever frequency you want and auto-select will only bring up the items
that are on the right schedule. We have A codes set up for 28 days, B
codes for 84 days, C codes for 175 days, and then I added a D code for 999
days. We've been using it for a year now and except for the fact that they
have to be sure and include all 0 quantity locations with the regular cycle
count - it works great and we actually will not be doing any more physical
inventories!
HTH....
Sent: Friday, December 03, 2004 10:22 AM
Subject: [Vantage] RE: ABC Codes & Cycle Counting
> Knappe & Koester
> 18 Bradco St
> Keene, NH 03431
> bbutler@...
> p.603.355.1166
> f. 603.355.2266
> Message: 14
> From: "Frank Zeigafuse" <fzeigafuse@...>
> either
> Frank Zeigafuse
> General Manager
> From: Lepley, Scott A. [mailto:sal@...]
> Frank,
> me
> designed,
> Regards,
> Scott Lepley
> Mauell Corporation
> Fax: 717-432-8688
> Email: sal@...
> From: Frank Zeigafuse [mailto:fzeigafuse@...]
> Frank Zeigafuse
> General Manager
> From: knappetech [mailto:bbutler@...]
> Do you count daily?
> Bruce
> Yahoo! Groups Links
Thank you Julie. This was exactly the kind of information I was looking
for. That is my ultimate goal: NO MORE PHYSICAL INVENTORIES! I have
been using cycle counting for a while, but not in the way it was
designed. I would generate Crystal reports to go after the inventory I
wanted counted, and would have someone key in all the part numbers from
the report. This enables us to get initial count dates into the system
so when I finally figured out how I wanted to go about using the system
as designed, at least, that part of it would be done.
Some followup: Roughly, how many hours a month do you spend counting
per person? And How many employees do you have?
Knappe & Koester
Message: 2
Bruce:
HTH....
Bruce:
Glad to be able to help.
We have 120 employees right now, but even when we had up to 150, the amount
of time for cycle counting was still about the same.
We have one full-time "cycle counter". He spends an average of about 2-3
hours a day every day on cycle counting, the rest of his day is
investigating problems and helping with material handling.
Just as a side note, this will be the first time we haven't had to do a
physical inventory, even though for the last few years, we knew our cycle
counting was keeping our inventory accuracy percentage up there pretty high.
We KNEW that the physicals actually hurt the integrity of the inventory and
we spent months after each one trying to fix all the errors, but we
continued doing the physicals because our home office was requiring it. Now
we have proof that the cycle counts remain high in percentage of accuracy
and we are very excited not to have to do the physical inventory - in time
and effort saved for it and fixing it all up again later.
So, I wish you the best of luck!
Julie Lehmann
Sent: Tuesday, December 07, 2004 8:39 AM
> Knappe & Koester
> Message: 2
> Bruce:
> HTH....
> Yahoo! Groups Links
Julie,
Bruce
Message: 2
Bruce:
HTH....
Knappe & Koester
18 Bradco St
Keene, NH 03431
bbutler@...
p.603.355.1166
f. 603.355.2266
