ABL Not Updating Dataset
Thanks Jose, I had forgot about tt tables not being useful for updating in post-processing directives.
To: Vantage <vantage@yahoogroups.com>
Sent: Thursday, August 1, 2013 1:39 PM
Subject: Re: [Vantage] ABL Not Updating Dataset
You could do a GetBy ID
The way I handle these situations is as follows
Use tt Tables to get the primary key
Then using these keys I run a FOR EACH XX on teh real tables and update the
data there (if in 8.03) use UpdateTableBuffer
Then I use the Primary Key to run GetByID and basically "refresh" my
dataset before its sent to the UI (plenty of examples on the list) hope
that helps.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
 <http://www.usdoingstuff.com>
On Thu, Aug 1, 2013 at 1:35 PM, Ted Koch <tkoch77@...> wrote:
> How would I do a GetByID and then modify the resultant dataset in a .P
> file without using tt tables?
> From: Jose Gomez <jose@...>
> Sent: Thursday, August 1, 2013 1:04 PM
> can;t modify ttTables in Post it won't commit..
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
> On Thu, Aug 1, 2013 at 12:47 PM, Ted Koch <tkoch77@...> wrote:
> > Post-Processing
> > ScheduleEngine.MoveJobItem
> > Sent: Thursday, August 1, 2013 11:59 AM
> > Preo or Post? On What method
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Thu, Aug 1, 2013 at 10:36 AM, tkoch77 <tkoch77@...> wrote:
> > > Hi all,
> > > Can anyone tell me if they see something wrong with this code. Where I
> > > have MESSAGE STRING(ttJobHead.ReqDueDate). it prints the correct date
> in
> > > the appserver log, but the date on the job is never updated. Also tried
> > > updating ttJobHead.Date01 and that would not update either.
> > > Thanks,
> > > -Ted
> > > {Bpm/Bpm.i &OBJECT_NAME="JobEntry"}
> > > {Bpm/MiscCallContext.i}
> > > {bo/JobEntry/JobEntry_ds.i}
> > > define input parameter iJobNum as character.
> > > define input parameter iReqDate as date.
> > > {&TRY_PRIVATE}
> > > DEFINE VARIABLE morePages AS LOGICAL.
> > > DEFINE VARIABLE hJobEntry AS HANDLE.
> > > RUN bo\JobEntry\JobEntry.p PERSISTENT SET hJobEntry.
> > > IF VALID-HANDLE (hJobEntry) THEN
> > > DO:
> > > RUN GetByID IN hJobEntry (INPUT iJobNum,
> > > {&output_dataset_JobEntryDataSet}).
> > > FOR EACH ttJobHead.
> > > ASSIGN ttJobHead.Company = '100'.
> > > ASSIGN ttJobHead.JobNum = iJobNum.
> > > ASSIGN ttJobHead.ReqDueDate = iReqDate.
> > > END.
> > > RUN Update IN hJobEntry({&input-output_dataset_JobEntryDataSet}).
> > > END.
> > > ELSE
> > > DO:
> > > message "Could not create handle to hJobEntry.p!".
> > > END.
> > > DELETE OBJECT hJobEntry.
> > > {&CATCH_PRIVATE}
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
Hi all,
Can anyone tell me if they see something wrong with this code. Where I have MESSAGE STRING(ttJobHead.ReqDueDate). it prints the correct date in the appserver log, but the date on the job is never updated. Also tried updating ttJobHead.Date01 and that would not update either.
-Ted
{&TRY_PRIVATE}
DO:
RUN GetByID IN hJobEntry (INPUT iJobNum, {&output_dataset_JobEntryDataSet}).
FOR EACH ttJobHead.
END.
END.
ELSE
DO:
END.
{&CATCH_PRIVATE}
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all,
> Thanks,
> -Ted
> {&TRY_PRIVATE}
> DO:
> FOR EACH ttJobHead.
> END.
> END.
> ELSE
> DO:
> END.
> {&CATCH_PRIVATE}
Post-Processing
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all,
> Thanks,
> -Ted
> {&TRY_PRIVATE}
> DO:
> FOR EACH ttJobHead.
> END.
> END.
> ELSE
> DO:
> END.
> {&CATCH_PRIVATE}
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Post-Processing
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi all,
> > Thanks,
> > -Ted
> > {&TRY_PRIVATE}
> > DO:
> > FOR EACH ttJobHead.
> > END.
> > END.
> > ELSE
> > DO:
> > END.
> > {&CATCH_PRIVATE}
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
How would I do a GetByID and then modify the resultant dataset in a .P file without using tt tables?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Post-Processing
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi all,
> > Thanks,
> > -Ted
> > {&TRY_PRIVATE}
> > DO:
> > FOR EACH ttJobHead.
> > END.
> > END.
> > ELSE
> > DO:
> > END.
> > {&CATCH_PRIVATE}
that helps.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Post-Processing
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi all,
> in
> > > Thanks,
> > > -Ted
> > > {&TRY_PRIVATE}
> > > DO:
> > > FOR EACH ttJobHead.
> > > END.
> > > END.
> > > ELSE
> > > DO:
> > > END.
> > > {&CATCH_PRIVATE}
