We do something similar. We add a labor entry for the day with the
appropriate indirect code. We then filter those codes out of our
payroll data that gets sent to ADP. We can also then easily report on
those indirect codes.
--- In vantage@yahoogroups.com, "Shirley Graver" <shirleyg@...> wrote:
> We don't really use the Indirect Codes (We're on version 5) So I
set up
> appropriate diciplinary codes under Indirect. Added a "00000-
diciplinary"
> workcenter. We have a point system so I put a point value at the
begining
> of the indirect code description (+1.00 Excused Absenc) I also set
up a
> "00000 - diciplinary" Expence code with no GL relationship.
> When an employee has a disciplinary event. The supervisor goes
into labor
> entry, adds an Indirect labor detail, selects the Indirect labor
code and
> the disciplinary workcenter.
> I've got labor reports to process the point values by parsing out
the the
> point value. the "+" and "-" at the start of the point value adds
or
> subtracts points. It works fine as long as its kept up to date.
> Shirley Graver
> Systems Administrator
> Rubber Associates
Yahoo! Groups Links
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
