Accessing Access DB from different workstations
Did you set up the ODBC driver on that computer?
Go into Control Panel, Administrative Tools, Data Sources (ODBC) and
set it up the same way you have on your computer.
Of sheehanam21
Sent: Thursday, March 08, 2007 6:20 PM
Subject: [Vantage] Accessing Access DB from different workstations
I created an Access DB that determines the standards for different
jobs. This DB works great and prints out exactly what I need.
However, I put this Access DB on a different computer and now I cannot
access the tables. I receive an error that says: ODBC--connection
to 'PRGS91dODBC' failed.
Can anyone clue me in as to how I can distribute my Access database
for others to use?
Tony
for others to use?
Tony
Did you create an ODBC connection on each workstation? Make sure the connection name is the same as yours on your computer.
Sent: Thursday, March 08, 2007 7:20 PM
for others to use?
Tony
You need to create the odbc connection on each workstation that needs to
run the reports. The name of the connection has to be exactly the same
as the original connection. Also, make sure you set these connections
to "Read Uncommitted" and lock down the ODBC config files so it can't be
change by your users. This will help to insure your users don't
accidentally write to the datasbase.
Of sheehanam21
for others to use?
Tony
Yahoo! Groups Links
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
How do you lock down the ODBC config files?
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, March 09, 2007 9:31 AM
Subject: RE: [Vantage] Accessing Access DB from different workstations
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of sheehanam21
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
for others to use?
Tony
http://groups. <http://groups.yahoo.com/group/vantage/files/.> yahoo.com/group/vantage/files/.
http://groups. <http://groups.yahoo.com/group/vantage/messages> yahoo.com/group/vantage/messages
http://groups. <http://groups.yahoo.com/group/vantage/links> yahoo.com/group/vantage/links
Yahoo! Groups Links
