it really depends on how tolerant you want to be of bad or non-existent data being returned in the query. In the case of the try catch technique, make sure you are not suppressing any genuine errors that might be thrown, or the code does not result in inaccurate data being displayed.
Kunal
Sent: Friday, April 3, 2009 10:35:46 AM
Subject: Re: [Vantage] Accessing another table in Form Event
I tried something that seemed to work.
I just wrapped it separately in a Try, and in the Catch, set the nTranQty2 = 0.
It caught all errors I threw at it.
Does this sound like right solution, or better I check for null on the SqlDataReader?
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Friday, April 3, 2009 10:12:10 AM
I am 99% of the way there, just one small problem.
if checking for parttran records returns nothing (null) how can I capture that?
I don't know how to capture the null/empty dataset returned error.
The full thing is below, but maybe just looking at this helps:
I want to set the variable nTranQty2 to zero if the cnxDR datareader returns null or dbnull or whatever it is that is returned when the query returns no rows. (nothing I try works)
Thanks for any help
With cnxCMD
..CommandText = cnxSQL2
..Connection = cnxCN
End With
cnxCN.Open()
cnxDR = cnxCMD.ExecuteReade r(CommandBehavio r.CloseConnectio n)
While cnxDR.Read()
nTranQty2 = cnxDr.GetDecimal( 0) '(cnxDR("qtysum" ))
End While
cnxDR.Close( )
Code:
Dim edv as EpiDataView = CType(oTrans. EpiDataViews( "PartTran" ), EpiDataView)
Dim strJob as String = edv.dataView( edv.Row)( "JobNum")
Dim nTranQty as Single = edv.dataView( edv.Row)( "TranQty" )
Dim nTranQty2 as Single
Dim nQtyComp as Single
Dim cnxString as String = "Server='lottest01' ;Database= 'mfgsys803' ;User Id='sysprogress' ;Password= 'sysprogress' "
Dim cnxSQL as String = "SELECT qtycompleted FROM jobhead WHERE jobnum = '" & strJob & "'"
Dim cnxSQL2 as string = "SELECT sum(tranqty) as qtysum FROM parttran WHERE jobnum = '"& strJob & "' and trantype = 'mfg-stk'"
Dim cnxCN as SqlConnection
Dim cnxCMD as New SqlCommand
Dim cnxDR as SqlDataReader
Try
'nTranQty is value in the Quantity box on the form
' 'MessageBox. Show("What you typed in Quantity box: " & cstr(nTranQty) )
'Sets nTranQty2 to sum of tranqty on Parttran records
cnxCN = New SqlConnection( cnxString)
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read()
End While
cnxDR.Close( )
' 'MessageBox. Show("Sum of mfg-stk parttran transactions for " & strJob & ": " & cstr(nTranQty2) )
'Sets nQtyComp to job quantity completed
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read()
nQtyComp = cnxDR.GetDecimal( 0) '(cnxDR("qtycomplet ed"))
End While
cnxDR.Close( )
' MessageBox.Show( "Qty Completed on job " & strJob & ": " & cstr(nQtyComp) )
if ((nTranQty2 + nTranQty) > nQtyComp) then
MessageBox.Show( cstr(nTranQty2) & " received in to inventory from this job to date" & vbCR & cstr(nQtyComp) & " completed on the job to date" & vbCR & "Receiving in " & cstr(nTranQty) & " would result in overage." )
edv.dataView( edv.Row)( "TranQty" ) = 0
else
'MessageBox. Show("Correct Amount of transaction: " & edv.dataView( edv.Row)( "TranQty" ) )
end if
Catch ex as Exception
'Dim ErrorMsg as String = ex.ToString( ) & ": " & ex.Message
'MessageBox. Show(ErrorMsg)
Finally
cnxCN.Close( )
End Try
============ ========= ========= end code
Sent: Thursday, April 2, 2009 11:46:12 AM
couple of ways to do that...
first, just get the value from the corresponding row in the database.
second (and a bit more complex), is to typecast the GUID of the form element to a variable and extracting the contents of the form element. For example -
'declaration
Private WithEvents OrderQtyTxtBox as EpiNumericEditor
'typecasting, note that the GUID is shown in the properties for that form element in vantage customization screen
OrderQtyTxtBox = CType(csm.GetNative ControlReference ("692bd57a- dc19-4f78- b4ad-710a7437878 4"), EpiNumericEditor)
'get the value
MessageBox.Show( OrderQtyTxtBox. Value) or MessageBox.Show( OrderQtyTxtBox. Text)
the really cool thing about the typecasting is that you can trigger events using them too
Private Sub OrderQtyTxtBox_ leave(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles OrderQtyTxtBox. Leave
if OrderQtyTxtBox. text.length <> 0 then
'do something
End if
End Sub
to answer (2), you will probably need to put in a condition after you copy the value from the datareader to a variable. The easiest way, but not the recommended way, to do this is to simply throw an exception in the code and not do anything when the exception is caught (some coder out there reading this is probably cringing right now). Note that genuine exceptions thrown by bad code or data will be ingored similarly.
One little quirk with the datareader, everything it returns is a character string regardless of the column type in the database, so learn some string formatting and conversion commands.! :)
Kunal
Sent: Thursday, April 2, 2009 11:15:38 AM
Rob, it works nicely, as long as you don't care about the password exposed there.
Below is my code, I am almost there, thank you!
2 more questions.
1. how do I assign the value of a text box (txtJob) to a variable? (isn't this VB syntax?)
2. how do I cancel the _BeforeFieldChange based on the return value?
in this example, if cnxDR("partnum" ) = "ABC123" I want to break out and cancel
Private Sub PartTran_BeforeFiel dChange(ByVal sender As object, ByVal args As DataColumnChangeEve ntArgs) Handles PartTran_Column. ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldNam e]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column. ColumnName
Case "TranQty"
Dim strJob as String = txtJob.Text
Dim cnxString as String = "Server='server' ;Database= 'mfgsys803' ;User Id='id';Password= 'password' "
Dim cnxSQL as String = "SELECT partnum FROM jobhead WHERE jobnum = '" & strJob & "'"
Try
With cnxCMD
...CommandText = cnxSQL
...Connection = cnxCN
End With
cnxCN.Open()
While cnxDR.Read
MessageBox.Show( cnxDR("partnum" ))
End While
catch
end try
Case Else
End Select
End Sub
Sent: Thursday, April 2, 2009 10:20:20 AM
Subject: RE: [Vantage] Accessing another table in Form Event
Nice, I might have to try that one out.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg com/>
(Click the logo to view our site)
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Kunal Ganguly
Sent: Thursday, April 02, 2009 9:54 AM
In some cases the search adapter might not exist. In which case you will
have to use code to extract the data you need, for example -
Imports System.Data. SqlClient
Dim cnxString as String = "Server=[server] ; Database=[yourdb] ; User
Id=[user]; Password=[password] "
Dim cnxSQL as String = "SELECT [columns]" & _
" FROM [table] " & _
" WHERE [column] = '" & [static value or something from the form] & "'"
Try
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read
....... (cnxDR("col1" )) .....
End While
catch (ex as exception)
end try
the biggest drawback to this is that you are exposing a username and
password used to access the SQL server in the form code.
Kunal
From: Rob Bucek <rbucek@dsmfg. com <mailto:rbucek% 40dsmfg.com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Sent: Thursday, April 2, 2009 9:04:40 AM
Absolutely.. .you do have to have some associated way to link the
records, otherwise I assume you would be talking about a static value
and not a variable existing in another table based off of some value in
the current record set youre working with in a form. If I understand
what youre looking for perhaps this would be an example... this resides
in our start activity form under the MES module
Private Sub btnOK2_Click( ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnOK2.Click
'// ** Place Event Handling Code Here **
Dim edvSPA As EpiDataView = CType(oTrans. EpiDataViews( "Start"),
EpiDataView)
Dim vRes As String = edvSPA.dataView( edvSpa.Row) ("ResourceID" )
Dim vJob As String = edvSPA.dataView( edvSpa.Row) ("JobNum" )
Dim vAssy As String = edvSPA.dataView( edvSpa.Row) ("AssemblySeq" )
Dim vOper As String = edvSPA.dataView( edvSpa.Row) ("OprSeq" )
Dim Hooks as Integer = 0
Dim adpJO As JobOperSearchAdapte r = New
JobOperSearchAdapte r(StartProdForm)
adpJO.BOConnect( )
Dim record As Boolean = adpJO.GetByID( vJob, vAssy, vOper)
Dim dsJO As JobOperSearchDataSe t = adpJO.JobOperSearch Data
Dim dStd As Decimal =
dsJO.Tables( "JobOper" ).Rows(0) ("ProdStandard" )
Hooks = Math.Ceiling( (dstd*60) /17)
'msgbox(dStd)
adpJO.Dispose( )
btnOK.PerformClick( )
'msgbox(vRes)
If vRes = "PMB" Then
MessageBox.Show( "Number of Hooks: " & Hooks)
End If
What we are doing here is when an operator logs into a job on our paint
line (hence the reference to the operation code) it goes to the job oper
table to get the production standard, does some math and comes back with
a message box translating for him the amount of space on the line (in
hooks), that the part will occupy. The button references are that I
replaced the standard 'ok' button on the form. This is probably
irrelevant to what you will be doing. The key is the search adapter,
most if not all tables should have a method available to search a
record. Hope this helps.
Rob Bucek
FAX: 715-284-4084
Behalf
Of Tony Hughes
Sent: Thursday, April 02, 2009 8:51 AM
Subject: [Vantage] Accessing another table in Form Event
Can I access another table in Form Event code?
I want to open a table that has nothing to do with the tables behind the
current form, pull a value out and assign it to a variable in the event
handling code of the Form Event?
Kunal
Thanks for any help
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read()
End While
cnxDR.Close( )
Code:
Try
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read()
End While
cnxDR.Close( )
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read()
End While
cnxDR.Close( )
else
end if
Finally
cnxCN.Close( )
End Try
'declaration
'get the value
'do something
End if
End Sub
Kunal
2 more questions.
Case "TranQty"
Try
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read
End While
catch
end try
Case Else
End Select
End Sub
Rob Bucek
FAX: 715-284-4084
Of Kunal Ganguly
Try
With cnxCMD
End With
cnxCN.Open()
While cnxDR.Read
End While
end try
Kunal
EpiDataView)
adpJO.BOConnect( )
'msgbox(dStd)
adpJO.Dispose( )
'msgbox(vRes)
End If
Rob Bucek
FAX: 715-284-4084
Behalf
Of Tony Hughes
