Active homepage BAQ widget not displaying results
We are pushing users from the metro homepage to the active homepage. Our engineers were using a BAQ widget to identify work in their engineering workbench.
When I try to setup a BAQ grid on the active homepage I get no results, where I do get results if I run the BAQ directly from the designer.
I am the BAQ designer. I am a security manager. The BAQ does not have a security ID set.
I am assuming there is something else I am missing which is preventing the BAQ grid from giving results??? I tried taking it a step further and create a view in EDD and same problem, I cannot see any BAQ results.
I created other BAQs which just work. Not sure what could prevent some BAQs from populating and others from not. Any ideas as to what might be the problem would be greatly appreciated.
We are on Kinetic 2021.2
An update. The BAQs being used had a SORT BY clause on a UD date field. No explanation why but the sort by would cause no results to display on the BAQ Grid to not display. Removing the sort fixed the issue. Also, adding a sort to standard fields did not cause the same failure.
Hope this helps anyone with a similar issue.
