Hey,
I’m bleary eyed. I’m customizing the Job Traveler print dialog, and getting the error …
Compiling Custom Code …
----------errors and warnings------------
Error: CS0246 - line 101 (270) - The type or namespace name ‘UD14Adapter’ could not be found (are you missing a using directive or an assembly reference?)
** Compile Failed. **
… on the script below.
Care to take a look?
Joe
// Custom code for JobTravForm
// Created: 8/15/2017 3:18:36 PM
extern alias Erp_Contracts_BO_JobAsmSearch;
extern alias Erp_Contracts_BO_JobEntry;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
this.JobTravForm.AfterToolClick += new Ice.Lib.Framework.AfterToolClickEventHandler(this.JobTravForm_AfterToolClick);
this.btnPlanner1.Click += new System.EventHandler(this.btnPlanner1_Click);
this.btnPlanner1.Click -= new System.EventHandler(this.btnPlanner1_Click);
this.JobTravForm.AfterToolClick -= new Ice.Lib.Framework.AfterToolClickEventHandler(this.JobTravForm_AfterToolClick);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void btnPlanner1_Click(object sender, System.EventArgs args)
SearchOnPersonAdapterShowDialog();
private void SearchOnPersonAdapterShowDialog()
// Wizard Generated Search Method
// You will need to call this method from another method in custom code
// For example, [Form]_Load or [Button]_Click
bool recSelected;
string whereClause = string.Empty;
System.Data.DataSet dsPersonAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "PersonAdapter", out recSelected, true, whereClause);
if (recSelected)
System.Data.DataRow adapterRow = dsPersonAdapter.Tables[0].Rows[0];
txtPlanner1.Text = adapterRow["PersonID"].ToString();
private void JobTravForm_AfterToolClick(object sender, Ice.Lib.Framework.AfterToolClickEventArgs args)
if (Convert.ToString(args.Tool.Key) == "PrintPreviewTool" || Convert.ToString(args.Tool.Key) == "PrintServerTool" || Convert.ToString(args.Tool.Key) == "PrintClientTool")
MessageBox.Show("Check - Traveler " +Convert.ToString(args.Tool.Key));
// write to UD table
string plannerOut = "";
if(!String.IsNullOrEmpty(txtPlanner1.Text))
plannerOut += txtPlanner1.Text + "~";
// planner 2 - 5
// make sure the string begins and ends with separator if not blank
if(!String.IsNullOrEmpty(plannerOut))
plannerOut = "~" + plannerOut;
// write out to UD table
UD14Adapter adapterUD14 = new UD14Adapter(oTrans); // **this is line 101**
adapterUD14.BOConnect();
bool resultUD = adapterUD14.GetByID("JobTraveler","PersonIDList","","","");
if(resultUD)
//MessageBox.Show(adapterUD01.UD01Data.Tables["UD01"].Rows[0]["Number01"].ToString());
MessageBox.Show(adapterUD14.UD14Data.UD14[0]["Key1"]);
adapterUD14.Dispose();
