Add a hyperlink to a form
Delcare a class level System.Windows.Forms.LinkLabel
private System.Windows.Forms.LinkLabel MyLink;
Add a regular Tool to your vantage form in the locaito where you'd like your
link.
tkae note of the Location, and Size*
Remove it,
Then on initialize custom code put
MyLink.AutoSize = true;
MyLink.Location = new System.Drawing.Point(68, 102);
MyLink.Name = "MyLink";
MyLink.Size = new System.Drawing.Size(56, 13);
MyLink.TabIndex = 0;
MyLink.TabStop = true;
MyLink.Text = "Click Here";
MyLink.LinkClicked += new
System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.MyLink_LinkClicked);
Set the Size and Location to the ones you noted.
Find the control which will be the parent and grab a hold of it and the
MyLink as a control.
Make sure that on click event you do the following
private void MyLink_LinkClicked(object sender, LinkLabelLinkClickedEventArgs
e)
System.Diagnostics.Process.Start("http://yourURL.com");
Hope this helps!
Let me know if you can't get it to work and I'll try to help further.
*Jose C Gomez*
Software Engineer
*NEED HELP WITH AN EPICOR ISSUE THAT CAN NOT BE SOLVED ON THE LIST?
CHECK OUT MY NEW BLOG <http://www.usdoingstuff.com> OR CONTACT ME DIRECTLY*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Jun 2, 2011 at 5:08 PM, Jose Gomez <jose@...> wrote:
> LinkLabel control, you have to do it in the code. If you'd like i'll set an
> example for you in a while.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Thu, Jun 2, 2011 at 4:50 PM, randyweb <weber.randy@...> wrote:
>> v9.05 - is there a way to place a hyperlink on a form to a web site or
>> file location? For example on the Part maintenance form to a vendor site or
>> specification. I tried the TextBox and Label, looking for a hyperlink
>> property but it isn't there.
>> Thanks in advance.
>> Randy Weber
>> Rayotek Scientific
v9.05 - is there a way to place a hyperlink on a form to a web site or file location? For example on the Part maintenance form to a vendor site or specification. I tried the TextBox and Label, looking for a hyperlink property but it isn't there.
Thanks in advance.
Randy Weber
Rayotek Scientific
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks in advance.
> Randy Weber
> Rayotek Scientific
