Within Kinetic, I’ve created a layer in Application Studio that added a few UD fields and added some existing fields to be required. I added that layer to Kinetic and it works well.
Now I’d like to add that layer to the Mobile CRM. Currently, in the mobile app, the original fields exist on the Opportunity/Quote screen and when you try to save it, you get an error that the additional fields I set to Required, are in fact Required. Problem is, those field don’t display on the entry screen so it’s impossible to add data to the fields.
I assume I solve this by adding the layer I created in the Menu Maintenance > MobMenu area, but my attempts have failed.
Any ideas?
Ryan
