Are you referring to a customization where you'd add in a text field and map it to the RptParameters.Character01 field, which then gets sent over to the report?
Sent: Wed 12/15/2010 4:07 PM
Subject: [Vantage] Add BAQ Report to UI Print Options
I ran across a piece of code somewhere on this board to launch a BAQ Report and pass some report parameters from a Vantage UI similar to "Receive Transfer Order".
I can't remember if it was just a code sample in a post or if someone had actually posted something in the Files section but after quite a bit of time trying to find it again today I am coming up empty.
Can anyone point me in the right direction?
thanks,
Nathan Bonner
bonner.n@
totalplastics.com
269.553.5838
thanks,
Nathan Bonner
bonner.n@
totalplastics.com
269.553.5838
