Sorry forgot to include the code
// Custom code for ResourceSchedForm
// Created: 11/5/2012 9:22:09 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.BO;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
using Infragistics.Win.UltraWinGrid;
using Epicor.Mfg.Core;
using Epicor.Mfg.Lib;
public class Script
private EpiUltraGrid grdList;
private BOReader boReader;
grdList = (EpiUltraGrid)csm.GetNativeControlReference("f505d266-c231-4bad-89f8-466141392d49");
grdList.InitializeRow += new InitializeRowEventHandler(grdList_InitializeRow);
boReader = new BOReader(((Session)oTrans.Session).ConnectionPool);
grdList = null;
grdList.InitializeRow -= new InitializeRowEventHandler(grdList_InitializeRow);
boReader = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
private void grdList_InitializeRow(object sender, InitializeRowEventArgs e)
string jobPartNum = e.Row.Cells["JobPartNum"].Value.ToString();
string whereClause = String.Format("PartNum='{0}'",jobPartNum);
string fieldSelect = "Character04";
DataSet dsPart = boReader.GetRows("Part",whereClause,fieldSelect);
if(dsPart.Tables[0].Rows.Count > 0)
e.Row.Cells["PrintName"].Value = dsPart.Tables[0].Rows[0]["Character04"].ToString();
dsPart = null;
private void ResourceSchedForm_Load(object sender, EventArgs args)
// Add new column to grdList
grdList.DisplayLayout.Bands[0].Columns.Add("PrintName","Print Name");
using System;
using System.Data;
public class Script
grdList = null;
boReader = null;
dsPart = null;
--- In vantage@yahoogroups.com, "jgiese1988" <epicor-team@...> wrote:
> I have added the Character04 field from Part to the Multi-Resource Sched board. It works with the code pasted below, but it is sloooooooooooooooooooooooowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww.... is there another way I can be doing this for a grid that has so many rows? ideally in a BPM?
