Add Columns to Customer -> Activity -> Shipments
I am trying to add 2 fields to the ‘Shipments’ grid in Customer Tracker/Entry in the ‘Activity’ section.
Specifically the Unit Price of the part associated with the OrderDtl line in the PackId/Line and a calculated field which is just that unit price * the total quantity shipped.
I tried following the steps in this thread How To: Adding Columns to Existing Kinetic Grid
I tried the ‘Version 2’ method as it seemed appropriate because I liked the idea of creating a BAQ to get the columns I needed and associate them with the existing grid.
Following a guide is one thing, but as soon as it doesn’t work I quickly feel over my head when I try and understand if/where I am going wrong.
I also see that using a BPM is the preferred method to achieve this. Not sure if this method is appropriate because I am not trying to the the exact thing as it is laid out in that guide.
Any help would be greatly appreciated.
This is the BPM way:
@hackaphreaka I’ve had good success overriding the load event and passing the DataView to a Function. The DataView comes into the Function as a C# DataSet object.
  • Check for data.
  • Add the extra column(s) to the DataSet.
  • Set up a couple variables to hold foreign key data from your original DataSet.
  • Loop through the rows or your original DataSet.
  • Make a LINQ or LAMDA query to the related table(s) based on your foreign key(s) to retrieve your extra data.
  • Add the desired fields in into your newly created column.
  • Return the updated DataSet which App Studio can readily use as a DataView for the grid.
Works like a charm!
Here’s an example adding order term codes to the pack slip browse grid so AR knows which shipments to invoice.
try
  //string sMsg = "dsIn.Tables.Count: " + dsIn.Tables.Count.ToString() + "\r\n";
  if(dsIn.Tables.Count > 0)
    dsIn.Tables[0].Columns.Add("TermsCode", typeof(string));
    int iOrderNum = 0;
    //sMsg += "dsIn.Tables[0].Rows.Count: " + dsIn.Tables[0].Rows.Count.ToString() + "\r\n";
    foreach(DataRow dr in dsIn.Tables[0].Rows)
      Int32.TryParse(dr["SalesOrder"].ToString(), out iOrderNum);
      var OrderRow = (from tc in Db.OrderHed
                    where tc.Company == Session.CompanyID
                    && tc.OrderNum == iOrderNum
                    select new { tc.Company, tc.OrderNum, tc.TermsCode }).FirstOrDefault();
      if (OrderRow != null)
        dr["TermsCode"] = OrderRow.TermsCode;
    //this.PublishInfoMessage(sMsg, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
   // Finally fill our variable with the updated results
   this.outDS = dsIn;
catch (Exception ex)
    //The following stops this dead in it's tracks.
    //throw new Ice.BLException(ex.Message);
    //The following allows it continue but shows error message.
    this.PublishInfoMessage(ex.Message, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
e: nm, works a treat, thanks.
