Add ECO Opr
I created a workflow to add BOO . I used UpdateExt method. After processed the files when i see in Inbound Message it stuck. How to solve this please share the solution.
have you get the DMT module ? it is very easy and straightforward task if you set the required template that suit your environment
Thank you dear for your post.
my view in SC we can do the automation kind of jobs n DMT it not possible.
but anyway i have solved the problem. I have re-import the .NET references and after that SC workflow is working perfectly.
