Add fields to crystal report
I will check my relationships and see what I come up with
--- In vantage@yahoogroups.com, "advantage" <advantage@...> wrote:
> First of all what vesion?, What report; canned, custom? did you add the 2 tables to RDD? on the Crystal? XML? ODBC? Relationships have to be defined in the RDD as well as the Crystal; Is it a subreport?
> From: Chris Thompson
> To: vantage@yahoogroups.com
> Sent: Wednesday, August 19, 2009 11:12 AM
> Subject: Re: [Vantage] Add fields to crystal report
> I had something similar to this and it was due to the link setup from within Crystal.
> From: elizabeth woning <elizabeth@...>
> Sent: Wednesday, 19 August, 2009 15:57:28
> Subject: [Vantage] Add fields to crystal report
> I have added 2 tables to a report in order to add fields in the crystal file.
> When I drop those new fields on the layout, all the data in the preview disappears.
> What could this relate to ?
Â
