i´m in the need to add some information to existing already posted invoices. i know posted invoices are not available for edition, but the info I´m trying to add/modify belongs to the APInvDtl_UD table… I know for sure those tables are editable since i´ve created the custom for the APInvMsc_UD table…
the issue is that i haven´t been able to point to the current APInvDtl dataview row… and it always seems to take row 0 as default… do you know what do i need to do to get current row in this line?:
no, i have not, actually I´m creating the custom over the APInvoiceTracker.
I know the EpiDataView.Row should do the “trick” since as i have already build a custom for the same purpose but using the APInvMsc_ud fields… right there it is working properly… i don´t know why it is not while using the APinvDtl table…
i´ve tried building an updateable dashboard but unfortunately i can´t even create the updateable BAQ, i keep receiving the message that posted invoices can´t be updated, no matter if I’m trying only to modify APInvDtl_UD fields… should you have any suggestion on what methods should in the updateable BAQ?
let me see if I can find something here in the group, related to BPMs, since I have zero experience writing them. Should you have any tip or guide would be awesome.
