I am trying to write a calculated display field on a BAQ. Does anyone have a way of adding a date field within Epicor with static integer field?
Example - I am wanting to add PO Due Date with the receive time field to show that the material will be available on X date.
I am not sure if the add interval field is capable of completing this task or if this is my error in the the formula.
Like @Mark_Wonsil said, we need a bit more info. However, this should be entirely possible. I think you will be looking at using the dateadd function. Dateadd is pretty flexible and can handle a wide variety of data.
Good luck!
as @Banderson suggested, the DataAdd() feature should do the trick. You create a calculated field and use this against the date in question to get the date you need. Just remember that DateAdd will not take into account weekends.
