Add Miscellaneous Header Charges to EDI orders (through the .APP file import)
In using the EDI import file (the tilde delimited text file). Is there a way to pass through a miscellaneous header charge (using percentage and not amount)?
I’m seeing that the tilde (.APP) file supports header, detail and schedule fields. But I don’t see anything on Miscellaneous Header charges.
I did notice that in Demand Entry you can had Miscellaneous Header charges, so I would imaging that the .APP file being imported can support the Misc charges as well.
Do you have this guide?
Epicor Kinetic Inbound EDI Transaction File Mapping
there is an extra charges mapping.
Extra Charges Rows (Linked to Demand Header and Demand Detail Rows)
Extra Charge rows in inbound EDI files contain extra charge data (such as rush or expedite fees) that relate to the Demand Header or Demand Detail rows to which they are linked.
The Epicor application stores this information in the DemandMisc table and then uses it to generate invoice charges for orders created from demand entries. This row type is Optional.
That’s interesting. Is there any documentation on this so I can test a tilde delimited file?
I found the guide. Thanks for your guidance.
