Add new column to Planning Workbench
Hello People,
I have been tasked with adding a new column to the Planning Workbench. After discussing it with my colleagues, the proposed plan is as follows:
  • Create a BAQ replicating the contents of the current Planning Workbench.
  • Add a retrieve button, similar to one that already exists on another screen.
  • Upon pressing the button, the Planning Workbench will display the BAQ I’ve created, including the additional field.
While this approach seems feasible, I believe there might be a more straightforward solution, such as requesting Epicor to implement the column directly. However, my co-workers feel that Epicor will provide a generic response and not make the change.
Would you have any insights or recommendations on whether there’s a more efficient way to achieve this, or is the proposed method the most effective approach?
The column in question is OrderHed.ReadyToCalc.
