Add New Custom .rpt
To modify one of the standard crystal reports (not a BAQ report): In
Report Styles (under Company Maintenance), find the report you're
copying from (SOBacklog) and add a new report style to it, with your new
.rpt filename. Copy the other information from the "Standard - Crystal"
style. You can then choose that new style in the print screen (or make
it the default). There's a bunch of other possibilities, but if you're
just tweaking the layout, that's enough.
Brian.
Of rae ann
Sent: Monday, February 14, 2011 12:25 PM
Subject: Re: [Vantage] Re: Add New Custom .rpt
It is just a copy of the standard SOBacklog.rpt
----- Original Message -----
Sent: Monday, February 14, 2011 12:17 PM
Subject: [Vantage] Re: Add New Custom .rpt
Was this an ODBC report?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
Gomez <jose@...> wrote:
> You can't just make an RPT and drop in the folder, you have to have a
> DataSet defined for it and a process / menu to call it, start with BAQ
> Report and work your way there.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Mon, Feb 14, 2011 at 11:47 AM, ladyvol <raeannk@...> wrote:
> > I am using 9.05.600b and am new to the sofware. I made a report and
placed
> > it in reports/customreports. Does anyone happen to have the steps
for adding
> > the report documented?
I am using 9.05.600b and am new to the sofware. I made a report and placed it in reports/customreports. Does anyone happen to have the steps for adding the report documented?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
If its just a copy with some layout mods field changes with existing
data, or if you added new fields and reconciled them with the RDD, then
under system/company/report styles, search for your report, then add a
new style (don't overwrite the default) and add your new report. See
the help menu for further details
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of rae ann
Sent: Monday, February 14, 2011 11:25 AM
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
placed
for adding
