Add Operation Comment to Multi Resource Scheduling Board List
Good morning,
I would like to add a column to the Multi Resource Scheduling Board (MRSB). I want to insert the Operation Comments into the List view. I am not sure how to edit the underlying dataset in an already existing form. I checked the personalization and the columns available do not include the operation comments.
I also considered creating a BAQ that could return essentially the same data as in the MRSB list view, but that sounds just as difficult.
What’s the consensus? Should I make a BAQ, or figure out how to insert a column in a customization? What is the right approach?
Thanks!
Nate
I went the BAQ route. I got close enough with this. You will have to edit the criteria for your environment and resources. This gives us what we need for now.
MRSBwOpComment.baq (47.8 KB)
