Add other selections to MES Shift Selection Screen
We are looking to add some “Covid Screening” questions to the MES screen when our users login…My initial plan was to add on to the “shift selection” pop up so they have to answer the questions before they can even clock in…however the LaborHed row isn’t active until they select the shift so any items I add to that screen are locked…starting down the path of having another form pop up when the shift selection one closes, but even if I go that route, they would still be able to carry on and clock in/use MES without actually having to select anything from that second pop up…any ideas out there or anything you guys have implemented at your companies??
Assuming that you open another screen using LaunchFormOptions, you could just set the IsModal property to true. This would prevent them from clicking anywhere else until the finished up on that screen.
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.IsModal = true;
I think that will get me to where I need to be. Thanks @cfinley. Will confirm once I get it all together!
