Hi,
What is the easiest way to add resources to a particular job? Can it be done from the Scheduling board? I know it can be done in the job entry screen but was wondering if there was another place (easiest) to add resources.
Thank you,
Daniel
Hi,
Thank you,
Daniel
Can you change the method to call out the desired resource? Or is it a one-time thing (in which case you probably have to edit the job).
I have products that 95% of the time will run on 4 machines and some others that 95% time will run on 2 machines.
From my view, it appears that you have to visit your resource group construction - perhaps one group of machines (or two), with the routing calling out the particular resource in the group.
