You have to format the field you want in the query that the dashboard utilizes. There is a format option for fields in the BAQ setup under the calculated field. The format ( >>>,>>9.99 ) without the parens will add a comma to anything under 100,000.00. Data type should also be set to decimal.
--- In vantage@yahoogroups.com, "jortega4087" <jortega@...> wrote:
> Is there a way to add these commans to dashboards summaries? I've looked everywhere and don't see a place to do this. We're on 8.03
> Thanks
