I have reset the APP server (we are on SQL) but no luck with what I am trying to do. It appears the the view used by Epicor in the screen is a view composed of multiple tables joined to make the view.
So, to change angles on this, is the best procedure going to be to link to a User-Defined table and build the connections myself. Thats a lot of work just be able to store a number field with the table record...
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> If on SQL restart your APP Server(an hope for the best). if not on SQL they
> dno't always show up for all tables. It depends on how Epicor did that view.
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com> *
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Tue, Oct 11, 2011 at 3:09 PM, tchristie1 <tchristie@...>wrote:
> > I have added a extended user defined table field called leadtime to the
> > table VendPBrk. I would like to be able to use the field on the suppler
> > reponse form, on the tab for price breaks. There is a dataview called
> > "priceview" that contains this table and a few other elements. It does not
> > show my new field.
> > A BAQ on the VendPBrk table does show the added field correctly.
> > Any suggestions as to how to get the epibinding for a textbox to this
> > field?
> > Thanks for any help.
