Yes I do and will have a look for it. One issue is that the print labels routine is not a normal report. It contains some logic that calculates the number of labels, depending on quantity per container and total quantity. Even this I could work around if I could figure out how to tell Crystal to print a multiple number of times depending on a parameter passed.
Thanks for the tip
Thanks for the tip
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> Hi Carl,
> Do you have access to EpicWeb?
> They have this tech tip that covers the basics:
> Search on: cust button
> CUST Code Examples to Launch Reports from a Button Click Event
> --- In vantage@yahoogroups.com, "CarlH" <carl.heeder@> wrote:
> > There is a button used to Print labels that shows up on incoming inspection and the same functionality is located under Actions in Material receipt.
> > I'd like to make this same functionality available on some other forms/menus.
> > Does anybody have an idea on how can I do this?
