Adding A Dataview in a Quote Form -- Error on GetRows
Hey folks,
I’m adding a new layer to the quote entry form. No other layers exist.
I need to display customer information on the quote header, so I’m adding a Customer dataview and trying to get the info after the GetByID. Getting an error when reading the data after the quote record is loaded, I think.
Here we go.
Add the dataview:
and select Guided Setup.
Source type: BO Service Call:
Set where clause to Binding (I have also tried Constant: CustNum = [QuoteHed.CustNum])
I’ve tried leaving all the other whereclauses either emtpy or Constant and an empty value.
Select the response parameters:
Attach the dataview:
Summary:
Set the GetRows event trigger:
Check the GetRows parameters:
I have tried editing in CustNum = [QuoteHed].[CustNum] but it doesn’t stick, and have tried making this a constant of CustNum = [QuoteHed.CustNum], among other things.
Save and preview. Load a record–the record displays and then an error message displays:
I have tried a bunch of variations on a theme here, but I must be missing something. Take a look and see anything (operator error) that stands out?
I can probably make a BAQ work here but would rather not have the extra component.
Joe
Your brackets are probably not helping the interpretation of your query filter. Try CustNum = {QuoteHed.CustNum} … or for good measure, "CustNum = '{QuoteHed.CustNum}'"
The curly braces are what tells the application to grab a value from the context, and you have to have the whole Where clause in your field value
Sometimes you just gotta display your ignorance for all to see. That was it.
Thanks, Jonathan.
Joe
Don’t you love it when you’re so close, but just can’t make it around the corner? :sweat_smile:
That’s what we’re here for :people_hugging:
Jimmy Fallon Reaction GIF by The Tonight Show Starring Jimmy Fallon
