Adding a JobPart with Service Connect
Why not first do a getbyid to return the jobentry dataset.
Then perform the actions you describe?
Of Steven Pybus
Sent: 24 September 2008 01:03
Subject: [Vantage] Re: Adding a JobPart with Service Connect
I'm invoking three web services:
1 JobEntryService.GetNewJobPartRequest
- sending it the Company and existing Job that I want to add a job
part to.
2 JobEntryService.ChangeJobPartPartNumRequest
- sending it the JobHead and JobPart data that no 1 above returned
but replacing the JobPart Parnum w/ the actual.
3 JobEntryService.UpdateRequest
- sending it the JobHead and JobPart data that no 2 above returned
but replacing five JobPart fields with the actuals.
Following 3 is where it returns the error. It's weird in that you've
got to have a job to add a job part to it, but it's insiting on a
unique value.
Thanks for considering what might be causing this.
-Steve P.
"Stephen Edginton" <stephene@...> wrote:
> Have you tried testing with BL tester.
> It could be an error in the webservice dll's
> The BL tester uses the same objects as the Client, so if you can do it
> in the client it will work in BL Tester.
> However the Web service dll's do a little more than just wrappers
around
> these and sometime introduce there own errors.
> Are you calling getbyid first etc etc provide a little more detail
> Regards,
> Stephen
Behalf
> Of Steven Pybus
> Sent: 24 September 2008 00:35
> Subject: [Vantage] Adding a JobPart with Service Connect
> I'm getting a strange error in my workflow when I try and add a
> JobPart to an existing job using service connect. When I try and
> execute the JobEntryService.Update, I get and error that says
> 'Company, JobNum' is constrained to be unique. When I turn tracing on
> and do this manually, the only company and job number returned in the
> data is the current job. Has anyone been successful in getting this
> done? We are using Vantage 8.03.305L.
However the Web service dll's do a little more than just wrappers around
Regards,
Stephen
Of Steven Pybus
part to.
unique value.
-Steve P.
> Regards,
> Stephen
> Of Steven Pybus
