Adding a "List" tab
Hi All,
E9.05.702A
I would like to add a List tab to the Time and Materials Invoice Review screen to show all the invoice lines in one grid.
T&M invoices can have many lines and it would be easier to review them in a grid as opposed to move line by line on the Lines tab.
I haven’t attempted this before, but I’m thinking it’s doable.
I was wondering if someone could provide a little guidance on what properties need to be set on the EpiUltraGrid to make this work.
I am looking to have the similar functionality as a standard List tab where I can make updates and the changes are saved as I move from line to line.
JOE ROJAS
Epicor Applications Manager
VENTION MEDICAL + DESIGN & DEVELOPMENT
Advancing Your Innovations For Health
261 Cedar Hill Street | Marlborough, MA 01752
DIRECT: 508.597.1392 x1625 | MOBILE: 774.826.9245
EMAIL: JoRojas@ventionmedical.commailto:JoRojas@ventionmedical.com | WEB: ventionmedical.com http://www.ventionmedical.com/
THINK QUALITY. BE QUALITY. GO BEYOND.
This communication may contain information that is confidential, proprietary or exempt from disclosure, and is intended only for the use of the individual and/or entity it is addressed to. If you are not the intended recipient, please note that any other dissemination, distribution, use or copying of this communication is strictly prohibited. If you have received this message in error, please notify the sender immediately by telephone or by return e-mail, and delete this information from your computer.
Couple of ways depending on whether you want to be able to make changes or not. If so, build an updateable dashboard and embed it on a custom sheet. If not, create a BAQ for the information and set the DataSource of the EpiUltraGrid to the BAQ results.
I have done the former in Customer Shipments to show a list of open Sales Order Lines.
	private void GetOrderShipLines(string orderNum)
		try
			DynamicQueryAdapter queryAdapter = new DynamicQueryAdapter(this.oTrans);
			queryAdapter.BOConnect();
			string queryID = "OrderRelBalance";  // <-- Change to your BAQ
			QueryExecutionDataSet parameters = new QueryExecutionDataSet();
			parameters.ExecutionParameter.AddExecutionParameterRow("orderNum", orderNum , "int", false, Guid.NewGuid(),"A");
			queryAdapter.ExecuteByID(queryID, parameters);
			grdOrderLines.DataSource = queryAdapter.QueryResults.Tables["Results"];
			grdOrderLines.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.False;
			grdOrderLines.DisplayLayout.PerformAutoResizeColumns(true, PerformAutoSizeType.AllRowsInBand);
			grdOrderLines.DisplayLayout.Bands[0].Columns["OrderDtl_PartNum"].Width = 150;
			grdOrderLines.DisplayLayout.Bands[0].Columns["OrderDtl_LineDesc"].Width = 300;
		catch (System.Exception ex)
			ExceptionBox.Show(ex);
Thanks Brian.
I’ve seen some quirkness with embedded dashboards in the past but I will give this a go.
The main issue I’ve run into are where the DB doesn’t always refresh when going from record to record, which in this case would mean going from invoice to invoice.
JOE ROJAS
In the example, the GetOrderShipLines function is called in several locations so that the EpiUltraGrid is refreshed with the current data. This includes ShipHead_DataView_ListChanged, Form Load, Clear Form, Delete a ShipDtl record, etc. Any where a change is made that affects the data displayed, the function is called to refresh the data.
I really like binding the results of a BAQ to UltraGrid. It’s quick and easy.
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
dqa.ExecuteByID("Jobs_By_Press");
epiUltraGridJobs.DataSource = dqa.QueryResults.Tables["Results"];
Adding\using BAQ parameters is equally as easy to implement
Thanks for all the feedback.
I ended up just binding the grid to the desired dataview to achieve this and it worked out great.
I did add a little code to disable the functionality on the grid if the user was to click the Delete key.
JOE ROJAS
