Adding a new comments box
Hi All
So I have done this before but for the life of me can find my notes, I’m trying to add a new comments box to sales order entry screen. Now I have done this no problem, and then if my memory recalls I need to bind it to something so I went to UD user column Maintenance I found Orderhed_UD and added a new column called Qcomments, I then saved that and then regened the databases for both app servers and recycled the pool in iis. But when I go back into the screen to bind with the comments box I can not find my Qcomments in Orderhed_UD I feel I’m missing something any help would be great
Cheers
D
Did you recycle the App pools
When adding a UD field, I have found that I have to completely stop the application server before regenerating the database or it doesn’t take. So I stop the app server (wait for it to completely stop), regen the database, restart the app server and then recycle it.
Yes i did recycle the app pools. this is really odd
I will try this to see if it works, Have i done this in the right way?
firstly you regenerate the data models, then you regenerate the app pools.
however, this should be done out of hours, as it can stop processes running
Thank all i retraced my steps and regenerated it all again and and it showed up guess it was just a glitch in the matrix.
Thank you again
