Adding a pulldown to a EpiUltraGrid
I am just learning to work with in the Epicor UI
customization but have been working with .NET and Infragistics for several
years.
This is a link to Infragistics on how to do it:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=7841
Below is an example I put together using Epicor 10 the SalesOrderForm,
Bill To combo, and the LinesGrid.
In the example I am adding an unbound column (BillTo) to the grid and using the already existing Bill To combo on the form.
Hope this helps, and curious if others have experience doing this.
// Custom code for SalesOrderForm
// Created: 6/17/2014 5:30:34 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.UI;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level
Variables’ Comments! **
Begin Wizard Added Module Level Variables **
End Wizard Added Module Level Variables **
Add Custom Module Level Variables Here **
Ice.Lib.Framework.EpiUltraCombo
ucBillTo;
Ice.Lib.Framework.EpiUltraGrid
myGrid;
public
void InitializeCustomCode()
** Wizard Insert Location - Do not delete ‘Begin/End Wizard Added Variable
Initialization’ lines **
Begin Wizard Added Variable Initialization
End Wizard Added Variable Initialization
Begin Wizard Added Custom Method Calls
End Wizard Added Custom Method Calls
ucBillTo
= (Ice.Lib.Framework.EpiUltraCombo)csm.GetNativeControlReference
(“b7ebad77-c6fe-4050-85b7-47324b30ba45”);
myGrid
= (Ice.Lib.Framework.EpiUltraGrid) csm.GetNativeControlReference
(“bec51417-b286-4d61-a471-3912bc098905”);
//Add
an unbound column to the grid – this is where I will link the already existing
Bill To combo
myGrid.DisplayLayout.Bands[0].Columns.Add
(“BillTo”, “Bill To”);
myGrid.InitializeLayout
+= new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler
(grdSummaryOrderLines_InitializeLayout);
public
void DestroyCustomCode()
** Wizard Insert Location - Do not delete ‘Begin/End Wizard Added Object
Disposal’ lines **
Begin Wizard Added Object Disposal
End Wizard Added Object Disposal
Begin Custom Code Disposal
End Custom Code Disposal
-= new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler
private
void grdSummaryOrderLines_InitializeLayout(object sender,
Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
e.Layout.Bands[0].Columns[“BillTo”].ValueList
= ucBillTo;
I have created a Ultragrid embedded into the Quote form. The grid is joined up with UD08. I have setup extended properties on UD08 such that UD08.shortchar01 is associated with a UDcode. However, I would like for Shortchar01 to appear as a pull down in the grid view. Any thoughts on how to accomplish this?
[cid:image001.jpg@01CF8BB0.0B125710]
Regards,
Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
