Hi Lynn,
Thank you - yes I added Company to Company and yes I set the
datasource location. I will go to Epicor's site and download the
answer book to see if that will help.
Regards,
Linda
Regards,
Linda
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Did you also add the relationship OrderDtl.Company = Part.Company?
> The field Company = Company must be part of every relationship
> between any 2 tables.
> Also, you write that you verified the database; can I assume that
> before choosing the "verify database" command, that you used
the "Set
> Datasource Location" and chose your newly created xml file as your
> new datasource location?
> (Reference Vantage AnswerBook # 4778MPS, CR Modifying a Crystal
> Report in V8.xx)
> Lynn
> --- In vantage@yahoogroups.com, "lindalowney" <llowney@> wrote:
> > Hi Group,
> > I have added the Part table to a copy of the Sales Order Pick
List
> > in Report Data Maintenance.
> > I setup a relationship between OrderDtl and the Part table using
> > Partnum.
> > I put a few fields in the Included Report Fields.
> > I saved the report data definition.
> > I changed the Sales Order Pick List report to use the new Data
> > Definition.
> > I print-previewed the report in Vantage.
> > I opened the report file that I just previewed in Crystal.
> > I verified the database.
> > I can't see the new Part table.
> > What did I miss?
> > Regards,
> > Linda
