Adding a text box to a form
It is normal for the form, when first opened to have all fields, except the fields required to create or retrieve a record, to be grayed out and if customization is opened from that state, the field will show as read only.
Try bringing in a record and see if the field remains read only
--- In vantage@yahoogroups.com, "bmmpam" <bryan.mischler@...> wrote:
> I am adding an epiTextBox to the customer entry form and the ReadOnly property is set to False. When I save the change and close and reopen the form, the field is greyed out and is read only. I open up the properties and the ReadOnly property is changed to True. I have resaved it as false and it is not working. Any ideas on why this is defaulting back to True? I am on 9.05.607a.
Ddi you set the Property to read only?
If so you need to set the extended property of the field to read only
instead. IN 9.0XX go to Tools -> wizards - Extended Properties select the
field and set Read only
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> am on 9.05.607a.
I actually want read only to be false. I have tried setting ReadOnly to false on the properties tab of the Customization Tools Diagram window as well as in the Extended properties. I save and when I go back in to view the properties the ReadOnly is set back to True again. My text box is linked to ShipTo.Character01 for what that is worth.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > am on 9.05.607a.
