Adding and displaying field in Vantage
The grid view in the Costing Workbench > Cost > Manufactured tab uses the Mfg table which appears native to the screen. The Part table is not connected to this form. You might be able to do something with a foreign key view...
Gerry
--- In vantage@yahoogroups.com, "anithayedavalli" <anithayedavalli@...> wrote:
> Hi,
> I added a field in Part maintenance(Part.shortchar06).I want to add the same field in Costing Workbench->Cost->Manufactured parts.After the adding the same field here,it does not display the data from Part.shortchar06.
> Any suggestions will be really appreciated.
> Thanks,
> Regards,
> Anitha
Hi,
Regards,
Anitha
First of all, when you say "after adding the same field here, it does not
display the data from part.shortchar06; how did you "add the field"???
The Part.ShortChar06 field can appear in other forms two ways that I have
done: Foreign Key View or BPM that dumps into the data that is being read
Costing Workbench Cost Manufactured Parts is a process pulling costs for
manufactured parts from the CostPart
anithayedavalli
Sent: Thursday, October 15, 2009 10:43 AM
Subject: [Vantage] Adding and displaying field in Vantage
Hi,
Regards,
Anitha
